Having a problem with refrigerator not getiing cold. freezer side is running and cold, but refrigerator side warm. the motor appears to be running nonstop on freezer side at 7 on temp dial. when i bring it down to 3 or so it stops
Hi, There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
There are plenty of reasons this could happen like the following:
PROBLEM
POSSIBLE CAUSE
Loud operating sound level
• See "Sound Information" section for explanation of normal operating sounds
Freezer too warm. Compressor not operating
• Freezer temperature set too warm
• Defective compressor
• Defective overload or relay
Refrigerator too cold
• Refrigerator temperature set too cold
• Chefs Pantry control set too cold or misaligned allowing freezer air to escape into refrigerator section
• Freezer temperature set too cold
• Restricted condenser air
• Refrigerant shortage or restriction
• Refrigerant overcharge
Freezer too warm. Compressor cuts off on overload
• Heavy usage
• High ambient
• Defective condenser fan motor
• Loose or missing condenser fan blade
• Improper voltage
• Defective relay or overload
• Compressor motor winding
• Non-condensibles in system
Freezer too warm. Compressor operating
• Opened door
• Heavy usage
• Defective freezer fan motor
• Opened defrost thermostat
• Opened defrost heater
• Loose or missing freezer or condenser fan blade
• Heavily frosted evaporator
• Inefficient compressor
Refrigerator too warm
• Refrigerator temperature set too warm
• Return air or air supply duct blocked
• Chefs Pantry control set too warm or air supply tube blocked
• Heavy usage
• High ambient
Problem
Possible Cause
Freezer too cold
Long off cyde
• Low ambient
Short off cycle
• Heavy usage
• High ambient
• Light constantly on
• Poor door gasket seal
Long or continuous run cyde
• Heavy usage
• High ambient
• Inadequate condenser air flow
• Loss or restricted refrigerant
Short run cycle
• Light usage
• Low ambient
Exterior cabinet condensation
• High humidity. Design accepts beads of water on cabinet exterior after 4 hours with 0° to 2°F (-18° to -17°C) freezer food temperature and 38° to 40°F (3° to 4°C) refrigerator food temperature in 84% R.H. conditions. See "Typical Sweat Pattern" section under above conditions.
• Insulation void
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp. The problem could be the electronic control if
you have one or the mechanical linkages.
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
