Question about HP 48gx Calculator
The numbers 1-3 on the keypad wont work
The numbers 1-3 and the (-) keys on the keypad wont work
  • HP Master
  • 8,068 Answers
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Posted on Jun 16, 2010
Have a samsung touch screen mobile gt-s3650 problems with numbers on keypad
My touch screen wont work right on messages and numbers you hit the 1 key it comes up 2, Messages same press A it goes to D
Nov 22, 2010 | Audiovox Flasher V7 Cellular Phone
We have a sears 1/2 hp garage door opener model 139.53674SRT2, manufactured in 9/98. Today the keypad stopped working. I replaced the 9V battery. Not sure if the keypad just died or if there is something...
Odds are it just died but you can try programming it just to make sure.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in your 4 digit code and press enter. If this doesn't work it is dead. You can get a replacement keypad at Sears. Be sure to take the model number of the old keypad with you. It should be on the back of the old one. If not, take the model number of your opener. There are several models of keypads and all of them wont work with your opener.
Sep 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Nokia 5200 (Number keypads) will Not Working
u need to change the key pad until then it wont work.
two keypad IC's under the keypad and next to the keypad connector unfortunately all the keypad points are linked to the IC's and so even if one key doesn't work it is related to these IC"s in question UNLESS the keypad connector is dirty or sticky please do service your phone or take it to a reliable technician
Jul 01, 2009 | Nokia 5200 Cellular Phone
Keypad malfunction
its simple.i discovered it myself.remove the housing of the phone,then remove the white sticker above the keypad circuit.when your done insert the battery,turn on the phone and short circuit the backlight in the "Ok" key (not the center) in the upper left with the number "2" key.after that your phone will restart.and done
Jun 21, 2009 | Sony Ericsson K550i Cellular Phone
Nokia 6233 Keypad NOT WORKING!!!
change keypad and use k750i see the keypad socket on up side and do some changes their
Jun 14, 2009 | Nokia 6233 Cellular Phone
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad
You're kind of vague on your problem. If it's the smaller blue numbers for the calculator, you will need to use the function (fn) key. Hold the fn key and press the key the reads number lock (num lock), this should return the keys back to letters. You can find more info on the fn key and numbers lock under help in the start menu. If this isn't your problem, be more specific, and I'll be more than happy to help.
Jun 29, 2008 | IBM ThinkPad T42 Notebook
Some of my numbers wont work
you can take the phone to a repair mobile shop and ahve them replaced the flexcable in the phone or reflash the keypad flexfile into the phone for you.
Jun 15, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Keypad problem in my mobile
its because theres a soft rubber touching in the number pad which makes circuit easy if the rubber has torn or lost its softness it wont work so please change the number pad alone
Apr 23, 2007 | Nokia 6670 Handheld
HP 48gx Calculator Logo
223 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
