Question about Desa International White Wireless Plug In Door Chime
One of outdoor ringers does not work, not a battery problem (tried that), where do I get a replacement ...don't want to get whole new system
    President:
  • 1,099 Answers
the problem can be fixed by opening the ringer to check if there is a loose contact of wire on the panel board , also check for dry soldering, if found resolder , but if otherwise it will require you to take it to the manufacturer for proper diagnosis.
Thanks for asking...
Posted on Jun 03, 2010
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Nokia lumia 710 speaker phone and ringer don't
A friend of mine had the same problem. The 3.5mm headphone socket was playing up, thinking they were still plugged in. She plugged headphones in and give it a push and a wiggle, then took it out and now it works. Give it a try.
Nov 20, 2012 | Cell Phones
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
After a four day power outage, my APC BE325R buzzes continuously when started, even though nothing is plugged into it. Has the battery suddenly died, or does it require recharging? Its a very loud buzz -...
It is probably a bad battery. They usually don't last much longer than 2-3 years. You could try replacing the battery, but I would suggest just replacing the whole UPS with a new model.
Sep 08, 2011 | APC BE325 SURGE PROTECTOR + BATTERY...
I just purchased a mod. # UDW20553 system from Sams club The power ac adaptor on one of the outside cameras is not working, where can I get a new adaptor. Thanks, Dennis Falvey
Exercise warranty... you just bought it, contact Sam's for a replacement. Most of the transformers are 12 vDC, but I don't know the polarity. If you have installed the units, contact Sam's explainign that it would cost time to remove and re-install the camera's if they need whole system back...
Aug 16, 2011 | Uniden Udwc25 Wireless Weatherproof...
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Broken ringer
I discovered that I there was yet one more screw hiding under the little sticker near the antenna. Got that off, took the screw out, took the antenna off and the whole back came off fairly easily. The dead ringer (couldn't resist) was in the back casing. It's has a sticky backing so I pried that out, put the other one in and closed everything back up. Much to my delight, after having no sound from my phone for 18 months, I now have my ringer working again. And I saved myself $200!
Sep 06, 2008 | Palm Treo 650 Handheld
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
GE handset registration?
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger. (If the new battery is not charged yet, then you will have to charge it first!)
Dec 31, 2007 | Uniden Cordless Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Desa International White Wireless Plug In Door Chime Logo
255 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
