Question about Cosmi Print Perfect Platinum
I have Print Perfect Platinum and cannot open the file to load the program as there is no setup on the first disc. Help Help
  • 394 Answers
HI,
You can try putting the disc in your drive, go to my computer ,click on the drive you have the disc in. This should open the disc for you to load. Good Luck. ( By the way I am not a computer wiz,)
Posted on Jun 03, 2010
My Print artist has stopped working. The Cd rom in my PC is broken so I can't reinstall. What can I do
Print Artist Platinum 24 has stopped working - Fixya
www.fixya.com/.../t13886156-print_artist_platinum_24_stopped_worki...
Aug 4, 2012 - either right click on the setup program and select run as administrator or log in using an administrator account on your PC to install.
Amazon.com: Customer Reviews: Print Artist Platinum 25
www.amazon.com/Nova...US.../B00EPACO3M
Amazon.com, Inc.Find helpful customer reviews and review ratings for Print Artist Platinum 25 at ... Installed this piece of garbage a week ago to start working on a project for a major .... Software performs quite well once the learning stage has been passed.
Support : Nova Development Technical Support
support.novadevelopment.com/
I have a version of Print Artist that came out before version 21. ... When working in the program, it freezes and shows a message "Not Responding" message at the top of ... When exporting a project as a SketchUp file, it has unwanted triangles.
Print Artist Gold 25
Jan 19, 2016 | Nova Development Print Artist Gold 24 no...
Why can't I get Cosmi Print Perfect Gold to access files on my computer?
It is possible your Antivirus is blocking the install of this older program.
Usually you can disable the antivirus, install the program, and then re-enable your antivirus.
If you know how to view your disk in Windows Explorer, you can 'Right Click' on the setup file (often setup.exe) and choose 'Run As Administrator'. This allows your computer to update files that it would normally restrict
The last thing to try is to Right-Click that same file and choose 'Properties' (at the bottom). You'll then see this window:
wsdlo3uzukgygaaaabjru5erkjggg==
but the program name will be setup.exe or whatever you clicked on. Choose the Compatibiilty tab near the top. You'll see
naaaaabjru5erkjggg==
Check / click the box for 'Compatibility Mode', and choose Windows XP like I did in the picture above. Then click Apply, the OK.
Try your install again!
Hope this helps, all the best to you,
Kerry H
May 18, 2014 | Cosmi Print Perfect Gold Full Version for...
The program will not load to my new computer error message 1305
need to know you system befor can help what windows you are using or mac system. also on the back of the disk box says what it is compatible with and if there is any other softwear is need to work on you pc.
Mar 24, 2014 | Broderbund PrintMaster Platinum Version 18
Cannot load print perfect platinum on my Vista system. I purchased the program when I had an xp system
Find the program on your desktop
Right click and go to Properties
Click on the Compatibility tab
Check the Run this program in compatibility mode for:
Click on the drop down menu and select Windows Vista
Click OK
when you're finished
Aug 25, 2011 | Cosmi Print Perfect Platinum
Print artist platinum 22 does not want to install on our new computer with windows 7, is there a patch or some drivers that need to be installed?
Try launching the program in compatibility mode. If this is a disc you're trying to install from, click on Start, goto Computer, go into your DVD Drive, right-click the Setup's EXE file, then Troubleshoot Compatibility.
If this is just a Setup EXE file you are trying to load on your computer you can do the same. Just right-click and select Troubleshoot Compatibility.
When you're presented with a list of options, select "This program worked in an earlier version of Windows", then hit Next. Just follow the prompts and then try installing it again.
Feb 23, 2011 | Nova Development Print Artist Version 22...
Every time I try to boot up print artist platinum edition it says Print Artist Platinum has encountered a problem and needs to close. What do I need to do to fix the problem?
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
Jun 29, 2010 | Nova Development Print Artist Version 22...
I have PrintMaster Platinum 12 that has been corrupted. I have repeatedly attempted to delete it so that I may reload from disc. Control panel does not permit me to delete it. Help please.
HAVE YOU REINSERTED DISC TO COMMENCE A SETUP?
A LOT OF PROGS USUALLY WHEN CHECKING SYS, ASK DO YOU WISH TOO REMOVE ASK DO U WISH TO REMOVE OLD PROG.
IF NOT, YOU WILL HAVE TO ACCESS PROGRAMS, FIND THE FILE/RIGHTY CLICK/REMOVE/IF FAILS/OPEN FILE/REMOVE WHAT DATA YOU CAN/RESTART/TRY SETUP?
Nov 15, 2009 | Broderbund PrintMaster Platinum Version 18
I have the Printmaster Platinum Version17 , I cannot save to pdf files?
1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution".
2. Go to File/Printer Setup/Printer Setup.
3. Under "Name" select Broderbund PDF Converter v2.10d
4. Next, go to File/Professional Printing.
5. Select "Save As PDF".
6. At the next screen, type the name of the PDF file you want to save in "Project Name".
7. Under "PDF Resolution", select 600 dpi.
8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents).
9. Click on the "Save" button.
10. PrintMaster will save the PDF file to the folder you selected.
11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
Jul 28, 2008 | Broderbund PrintMaster Platinum 16
Drag to disc file
Make another disk and do it, so it works the way you want it to work.
Oct 29, 2007 | Roxio Easy CD & DVD Creator Platinum...
Cosmi Print Perfect Platinum Logo
91 people viewed this question
Top Cosmi Computers & Internet Experts
Tony
raysaw
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
