Question about Compaq Presario M2000 Notebook
That meanse your laptop/comp will stop working soon.
Actually, I have the same problem. The lines across your screen usually mean that theres something wrong with your lap top and it could very well cease to work very soon. My cousin's lap top stopped working after a couple of months since he has gotten lines on his. If you would like to fix it you would need to hire an expert to fix it, or you can buy a new laptop/computer.
    Guru:
  • 868 Answers
Ou can try to uninstall and einstall the drivers of your video card first
If your having Lines across your screen to find out if that would be the video card LCD or software which is windows try going into the BIOS of your system if the lines show in BIOS that would be a Hardware issue, now to eliminate the hard ware causing the lines on your screen go to safe mode where the video card driver is disabled if the lines still exsist then the lines that you see will be the fault of the LCD, third if you can connect to an xternal LCD or monitor and the Lines still Exist then the Video ard is also Faulty ^_^
Posted on Jun 04, 2010
If there is a wide faded vertical line that is showing on the screen and a black film that shows up periodically across the screen. Does that mean that the picture screen need to be replaced?
Picture tubes are one of the last components to actually die in any CRT television. Usually the only reason they are / were changed was due to colour degradation or dead pixels. I would be looking at either the colour boards or for yoke damage. If the picture still fills the entire screen then the high voltage section and tube are still OK.
Hope this helps a bit. Cheers Bob
Nov 17, 2016 | Televison & Video
Vertical line down screen
This problem can be caused by a lose connection between LCD and motherboard, however you can check it by opening the LCD or hinge bezel to ensure if there isn't any lose connection.
Oct 28, 2013 | Dell Vostro Computers & Internet
What is meanse "service!"?
its mean that your car reguler service is down
Dec 28, 2010 | 2005 Audi A3
Red line on comp screen reset driver dont work
This is, unfortunately, the screen starting to deteriorate, it will probably get worse and worse. It is a common thing, and is usually caused by the "Driver" "Chips" becoming faulty. There is no real "Fix" other than "Replacement"
Feb 12, 2010 | Acer Aspire 5500 5570-2609 Laptop
My LG KE970 LCD screen is distored with lines across it.
what im thinking is that 1. you might neeed to buy a new screen or 2. the LCD ribbon might of smuggled out. but i think more about having to buy a new screen
Aug 20, 2009 | LG Shine KE970 Cellular Phone
Lines on screen
I was going to ask to define lines, but if you have lines (red, green or white) usually means the screen is dying.
Full lines across the screen (such as in the case of my wife's laptop) mean the screen is dead. In either case, replacing the LCD is in order.
Good luck
God Bless
-Carlos:
Jun 12, 2009 | HP Pavilion dv8000z Notebook
Vertical Lines in Monitor
This is usually a screen problem and cannot be fixed however to verify if this is from the screen or from the video card you can connect a normal monitor to the back output connector of your laptop and check the display on the external screen.
This will tell you if it is the video card on the board or the actual screen. In either case it would be a hardware issue.
Sep 20, 2008 | Acer TravelMate 2300 Notebook
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Compaq Presario M2000 Notebook Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
