Question about Delta & Single Handle Shower Faucet
I'm not getting enough hot water from my delta 14 multi shower faucet. How do I set the temp?
    Scholar:
  • 81 Answers
Go to the link below then click on download. This will bring up a pdf file for the Delta 14 series. Scroll down to page 5 for instructions from Delta on how to adjust the temperature after removing the handle.
http://www.deltafaucet.com/customersupport/documentation/T14430-LHP%20H74%20A74.html?document=mi&documentIndex=0
Posted on Jun 03, 2010
I have a Delta scald guard shower faucet (older model). The cold water pressure is good but as a turn to hot the pressure drops to a drizzle. There are 2 other sinks and another shower upstairs and there...
It is more that likely the valve in the stem of your fixture, I'm assuming this is a single handle faucet. If you can replace the valve, you will cure your problem. I am giving you a link to how to adjust the hot water temp.
http://www.ehow.com/how_6531012_adjust-anti_scald-setting-delta-faucets.html
May 10, 2011 | Delta Home
We installed a new singel handled faucte in our shower and now we are running out of hot water. this never happened in this house before. we always have plenty of hot water, i called delta and they said...
The way the faucet cartridge is designed it will protect you from large changes in water pressure. This can happen if someone is useing the shower and someone else flushes a tolet there is a sliding valve in the cartridge that will close off hot water supply to protect you from getting scalded.If you are not getting hot enough water there are adjustment you can make to increase the maximum setting.
As long as you are getting good hot water supply in other fixtures in your house I doubt that changeing the water heater is going to help.
I think that you may have a defective cartridge and I would call delta again and give them another chance. They generally have very good customer service, and perhaps the one you talked do did not understand that you have good hot water supply elsewhere.
If you do not have hot enough water to shower valve that can eaisily adjusted by removing set screw that holds the handle on and remove the handle.If there is a white temp. limit disc on the stem then remove it. Slid the chrome sleeve from around the valve body off. You should see a disc that you can slid out a little and rotate to the left a small amount. This adjusting disc and its mating surface have teeth on them that mate. There should be marks on the valve and disc with a arrow on them to show which way to turn for hotter water.Reassemble and check.
If your water starts out hot and then gets cooler while being used and you still have hot water in other places then I think you have a defective cartridge. It should be under warranty. Hope this helps you some. Good luck and thank you.
Jan 26, 2011 | Delta & Single Handle Shower Faucet
Water not hot enough. How do you adjust the temp?
Hot water temperature is controlled at your water heating source.
Sep 01, 2010 | Delta & Single Handle Shower Faucet
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Water in bathroom sink is hot, but not hot in shower. Have a Delta Victorian 1 handle temp. faucet in shower. It is turned all the way over as hot as it will go, and still not hot enough. Had new parts put...
Remove handle and it has a dail in faucet that can be removed and repostioned, just remember where you started. maybe take out and replace it a 1/4 turn counter clock wise that should open range of hot water.
put handle back on turn on and see what you have if not hot enough take back out and move it a lttle more and replace and try again.
main thing just remember starting point before you moved it.
Mar 04, 2010 | Plumbing
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
I have a Brizo Shower and can't get the water hot enought
I am not sure but I think the shower will work with out the limiter on it .  try that
Apr 14, 2009 | Delta Plumbing
Water Temp not hot in shower
you need an allen key to remove the handle once the handle is removed than you need to turn the grey plastic temp guide counter clockwise as far as possible
Feb 01, 2009 | Delta & Leland Lavatory Faucet
Delta & Single Handle Shower Faucet  Logo
781 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
