I have a compaq presario computer SR1103WM My monitor displays on screen no operating system
    President:
  • 1,216 Answers
THE PC HAS CRASHED AND MUST BE RE STORED EITHER BY RE-INSTALLING THE OS OR BY RESTORING THE PC USING THE RECOVERY .IF THIS DOES NOT HELP BE SURE IT IS THE HARD DISK WHO IS THE CULPRIT.
Posted on Jun 03, 2010
  • 4,924 Answers
Check the hdd to be plugged and powered..if all seams to be ok ..than the operation system may be corrupted..or if you have a sata drive it may need a sata driver to be load for the computer to see the hard disk ..
try to reinstall it if nothing will work ..doing this will see if when you get to the search for previous operating systems ..it sees the hdd...this may be corrupted ..or gone ...or just the operating system faulty ..
Also boot to bios and restore to optimal factory defaults ..and than save with F10...(you will fin inside the key that you have to press for to do the factory defaults cause it is different for each bios variant )
another thing you should do ..is look into teh advanced(in bios) or ..devices...(it willbe the second page or the 3rd) and where the hdd and the cd /dvd unit are displayed it will be also a AHCI feature..and it need to be disabled in order to make the computer see your sata hdd..disable the AHci..and save setings with F10 ..reboot and try ..if this was the cause it may not need a reinstallation of the OS
My PC won't start? every time i start it the fan just spins fast and loud and nothing happens, the screen doesn't show. this happened when i took the PC apart. it a Compaq presario sr1610nx
Initially test the monitor in another pc, if display available use the monitor in Compaq presario sr1610nx. Load to BIOS by restarting and tapping F1, if the display available, the computer is ok. restart and tap F8, if the advanced boot option screen comes up, the software is ok.
Restart the computer and tap F10 and proceed with a destructive recovery to reload the operating system on the computer
May 07, 2010 | Compaq Presario 5000 PC Desktop
HI,switch pc on and it powers up ok but doesnot boot up.Cd drive will open and close but no display on monitor.?
you hav to check out boot drive... if it would be ok thn u need to just re-install boot driver from concerned window system support..
Dec 15, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
I have a compaq presario sr1103wm and it won't load windows. i turn it on and it goes to screen saying windows wasn't shut down properly and lists the options: start in safe mode, with networking, with...
re install or repormat your system to fix all problem will return into normal operation... but before that dont forget to save your data if you have important data dont'want to loss it..
if can't open the program or operating system remove your Hdd then insert into another computer to back up the data ot be sure that you have back up all important data. except those programs cant make back up... you need to re install again from the source..
Sep 17, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
My usb keeps sayin power surge on hub ports
You may need to upgrade to a higher wattage power supply, which would also help with the performance of your computer. Or try updating either your system bios or USB drivers.
Jun 20, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
LCD Monitor stays on 4 bit resolutionm
Its your VGA card that's having issues with the LCD display. Try reinstalling the VGA drivers see if it works.
Jan 22, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Black screen when i turn on computer.
Do a power drain :- Disconnect every cord from the back of computer tower while the pc is oiff and then press and hold down the power supply button in front of the tower..
have u tried updating the bios any time before?
Secondly,is it possible to go to the safe mode or the screen goes blank even before that?
Blank screen
When you say "When I turn on the computer the monitor acts like it is getting no power", do you mean the light on monitor doesn't come on or it does and it states it has "No Signal"? If it says no signal then it is receiving power just no signal from computer. What kind of connection is it? Digital(white) or analog(blue)? Is the keyboard wireless or is it PS/2?
If the keyboard isn't wireless and you're plugging the monitor in correctly I would say it's a power supply issue. Try changing the outlet you're using and/or bypass the surge protector to plug directly into wall.
Jun 24, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Needed Model# to help with Graphic Card
Your system model no. is :-PC182A-ABA SR1103WM NA430
Mar 18, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Monitor menu
that's a control issue with the monitor...you may need to get and reinstall the video drivers for that one...check this link, follow hp icon to model number, for computer, and look for video drivers.
Mar 16, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
