Question about Siemens HF87950GB Convection Microwave Oven
I have to replace the lightbulb in our Siemens HFT759. What do I have to remove to get access to the lightbuld?
Replace a lightbulb
The lamp is housed inside the outside enclosure which has to be removed to gain access for replacement. You should be aware that removal of the enclosure may expose you to hazardous voltages inside.
Feb 13, 2015 | Microwave Ovens
How do I replace the lightbulb in a GE Advantium 1200 microwave oven?
The outside cover has to be removed to get access to the lamp.
Jan 22, 2015 | GE Microwave Ovens
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
Inside lightbulb went out
look at the top. there may be an access thingy you can remove to get to the lightbulb. replace the lightbulb with suitable replacement. problem solved.
Feb 16, 2014 | GE Microwave Ovens
The inside lightbulb went out how do we replace it?
open the microwave. If there is a removable panel on the top, remove it and replace the lightbulb.
Feb 16, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
How to change the light bulp inside the oven?
Bulb replacement is not straight forward on this model, it requires the oven to be removed & stripped to gain access to the interior lamp... I recommend replacement by a Siemens engineer.
Mar 02, 2010 | Siemens HB77L25GB 900 Watts Convection /...
How do I change the lightbulb in the unit?
remove the screws holding the outer shell and carefully remove it.... the bulb should be accessable then. make sure the replacement bulb is equivelent to what is in the microwave now. do not operate the microwave without the cover on it. if possible test the bulb before you put it in.
Jan 17, 2010 | Sanyo EM-P410W Microwave Oven
How do I change the lightbulb?
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
Siemens HF87950 Internal Bulb replacement
Move unit forward out from enclosure about 20cm....the light is covered by a small panel on top of the casing.(uses torx T20 screws) Remove lid and replace bulb!
Apr 11, 2007 | Siemens HF87951 800 Watts Microwave Oven
Siemens HF87950GB Convection Microwave Oven Logo
203 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Bill Olaschinez
Bill Olaschinez
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
