Question about Zanussi ZBF660 Electric Single Oven
I have a Zanussi ZBF 860W and the power has gone. the clock is off and the oven will not switch on. Do you have any idea what the issue may be?
  • 1462 Answers
SOURCE: zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Posted on Jun 19, 2008
SOURCE: oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Posted on Feb 28, 2009
SOURCE: I need to clean between glass plate and oven door
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Posted on Oct 20, 2009
  • 417 Answers
SOURCE: zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Posted on Dec 26, 2009
  • 417 Answers
SOURCE: oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Posted on Jan 17, 2010
Testimonial: "concise. accurate. excellent. thanks!"
Zanussi oven zbf 360 + bulb blows repeatedly
bulbs blow from incorrect voltage in use or loose ground wires ( arcing out)
if they fail while the oven is on it is because the bulb construction glass is wrong
bulbs used in ovens need a special heated treated glass and are generally only available from the service agent
failing immediately on turning on indicates a bigger problem that the bulb so call in an electrician to test the system
Mar 24, 2017 | Zanussi ZBF360 Electric Single Oven
Oven has stopped working on zanussi zbf 360
Heating element is probably shot. Turn it on....does the element glow orange????
Mar 13, 2012 | Zanussi ZBF360 Electric Single Oven
Trip swich went when turned back on no power in oven at all
Hi intial problem will probably be a faulty heating element locatated behind the panel at the back. the zbf260 has no clock but if its a zbf 360 set the clock before the oven will function. otherwise the fault has damaged another component on the oven. which can be in order of most likley.fuse if on 13a supply/ thermostat/ selectorswitch/ thermal cutout/jw
Feb 09, 2011 | Zanussi ZBF260 Electric Single Oven
My grill element on my zanussi oven, ZBF 260, has stopped working. How do I remove the faulty part so I can replace it?
after isolating electric. remove oven from housing ( 2 or 4 screws) remove back of appliance to access retaining nuts .( disconnect wires noting terminal position). grill is fixed to roof of oven with screws remove these and take out grill. refit in reverse order remember to reconnect wires .
Aug 24, 2010 | Zanussi Ovens
Oven not working - rest of appliance fine
Jan 17, 2010 | Ovens
Zanussi zbf260x built-in oven keeps tripping out
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Zanussi zbf 760 (9 yrs old now)
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Zanussi ZBF660 Electric Single Oven Logo
52 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
