Question about GE Heating & Cooling
My air conditioner is GE AJCS12DCAMI and is isn't
My air conditioner isn't getting cool enough. It seems to stay on "low." Is it the thermstat or frion? Or something else?
  • 15 Answers
SOURCE: Air conditioner is not cooling. The fan is running. When I turn the thermostat past 7, the unit shuts down. Any ideas? Low on Freon?
Sounds like a leak to me - if you have a set of guages available (know anyone working in the refrigeration field???) you could tell this for certain.  Otherwise, try running it when it cools down outside and see what happens.  Take a stick thermometer, and put it in between the fins on the INSIDE condenser coil.  If they get cooler, but not down to about 50 degrees, then you are low on refrigerant.
Good Luck!
Posted on May 26, 2009
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
  • 340 Answers
SOURCE: my air conditioner is not blowing out real cold air
have it cleaned sounds like symptoms are like a dirty unit .
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
Posted on Oct 19, 2009
raulcvalenzu
  • 11 Answers
SOURCE: what could be wrong with my air conditioner in my 2005 mack dump
thermostat malfunction
Posted on May 27, 2010
Why does GE Portable Air Conditioner APE08 cool but does not remove moisture?
to remove moisture you have to get below the dew point of air. if air is not cold enough is a issue
Jul 10, 2014 | GE APN10AA Portable Air Conditioner
High efficiency outside air conditioner does not cool house, seems to for a while but stops. The pipes at the air conditioner are coated with ice so seems to produce cold but does not blow that through the...
Unfortunately, the ice coating isn't normal, in fact, it is an indication that your unit is low on freon or a blockage. But could also mean a few other things.
But about the only thing you can do yourself is make sure that the fan is turning or not.
Jul 07, 2011 | Frigidaire Heating & Cooling
Rudd air conditioner isn't cooling,blowing ,but isn't cooling my house because air is not cold
Hello, first check if the outside unit is running, if it is then check filter to make sure it is clean and that the blower wheel is clean and not dirty. If the unit is clean then most likely you have a low refrigerant charge due to a leak and will need a hvac tech to come out and fix the leak.
Jun 19, 2011 | Ruud UAMB Air Conditioner
Blower stays in low...
That will be in the lower motor,the speeds,so to fix the speeds,the motor will have to be replaced.
Jul 24, 2010 | Kenmore 70187 Air Conditioner
The fan in my compressor is not turning while my furnace is running, extreamly cold outside
If you are reffering to a heat pump.
That is by design.
the fan on the compressor like those in modern automibiles are thermstatically controlled.
It is an energysaving strategy.
They only work when necessary. If it is very cold outside, the compresor does not get warm enough to need fan cooling.
Since the air around it is enough to do so efficiently.
it is working fine and saving you on you energy bills too.
Jan 30, 2010 | Heating & Cooling
AMANA PTH153B35AE PTAC Temp drop??
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Jul 04, 2009 | GE Zoneline AZ55H07D Air Conditioner
GE Zoneline blowing hot air in afternoon.
Maybe but check the temp difference between outlet and inlet. Should be 25 to 30 degrees. Rus
Jun 29, 2009 | GE Zoneline AZ55H07D Air Conditioner
Coils freezing up!
Outdoor coils dirty creats high head pressure which in turn destroys a hermetic compressor for the fact that a hermetic compressor uses Superheated vapor to cool windings..Your post is so vague but for the fact you advise a service tech...
Jun 09, 2008 | GE Quiet-Aire Ductless Split System Air...
Fan Seems To Be the Only Thing Working
no you problably have a bad thermostat on the unit
May 27, 2008 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
