Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
My top shelve sprayer arm does not spin
My kitchenaid top shelf spray arm does not spin. I have check for obstruction - found none. All parts look good. Lower arm is spinning.
Dishwasher is filling with water to proper level and working properly except for the arm not spining. I have removed the top shelf and applied water pressure from exterior house water hose - arm still does not spin.
Arm will spin by hand. Help - How much water pressure does this arm need to see to work.
  • KitchenAid Master
  • 3,180 Answers
Its just clipped over the cap remove and clean also check the seal is not damages on the pipe that goes into case.
Posted on Jun 18, 2017
SOURCE: Dishes not cleaning particularly on top rack
Thank you, so much, for the update!
Lita
Posted on Jun 18, 2008
taran_2005
  • 10515 Answers
SOURCE: how do remove the sprayer arm?
Hi mathenywasja,
   For removal of spray follow :-
http://www.acmehowto.com/howto/appliance/dishwasher/check/sprayarm.php
http://www.partselect.com/repair.aspx?appliance=dishwasher∂=remove-spray-arms
To replace pump, procedure would be :-
The pump is not difficult to remove and replace. If you have a little bit of mechanical ability, you can replace the pump easily. You can find the pump by following the drain line into the bottom of the dishwasher. The drain line connects to the pump.
The pump will come out fairly easily by removing a couple of fasteners. Make sure you find an exact replacement part or you could be in for a world of trouble.
Thanks for using Fixya.
Do rate the solution.
Posted on Apr 16, 2009
  • 423 Answers
SOURCE: Frigidaire Dishwasher - Spray Arm Not Working
When a dishwasher has been checked for obstructions in the sump area and the spray arms can spin easily (by hand) plus the spray arm holes are not blocked, you end up with either a broken impeller or a failing wash pump motor.
If you would like more details of have more questions, please post comment back here, OK?
Good Luck!
Posted on Apr 26, 2009
  • 30 Answers
SOURCE: how do you remove the lower spray arm from a maytag mbd4100 dishw
go to managemyhome.com and type in your model # and get your manuals.
Posted on May 03, 2009
  • 28 Answers
SOURCE: Asko1585 sprayer arm not working
Most likely the circulation pump. On this pump there is mounted a condensator. This will help the pump to get started. If this is broken, it wont circulate the water up to the sprayers.
Posted on Jul 27, 2009
Top arm inside dishwasher fell off
You might need to reset or replace the spraying arm
Click on : Sprayer
Jan 23, 2013 | Dishwashers
My kitchenaid dishwasher the water does not get to the upper rack...and the dishes on the second rack on not clean at all....
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer
Jul 17, 2011 | KitchenAid Dishwashers
Dishes on top shelf do not get clean.
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 13, 2011 | KitchenAid Dishwashers
After filling and only when rinse commences a loud chattering noise begins. Somewhat like a circuit breaker making intermittent contact. It ends when I cancel and remains silent while the pump empties...
  • It sounds like you have an obstruction with upper or lower spray arm. check to see if the something is stuck in the path of the lower spray arm.
  • move the lower rack out
  • spin the spray arm by hand to see if it is hitting anything
  • if not .....spin the upper spray arm by hand under top shelf to see if it is hitting anything.
  • let me know how this works
Dec 30, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Top water sprayer not getting water. does not clean dishes on top shelf.
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Kenmore Dishwashers
The top spinner/cleaner dish sprayer thing isn't spinning or spraying water on to the dishes on the top shelf. The rest of the dishwasher works. Any suggestions on how to fix?
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Items in top shelf do not clean fully.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
sytrswgh
Jul 05, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Top shelf not cleaning
heatman101
qqqw
Jun 12, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher not cleaning items on top shelf. Water is not getting to the dishes on the top rack
heatman101
xxk
Apr 14, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishes on top shelf not cleaning
heatman101
4w56er
Mar 02, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
126 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
