Question about D-Link AirPlus DI-524 Wireless Router
Cannot connect new computer to old router.
I bought a new computer and tried to connect to the router. I tried to re-set it; however, it's requiring user and password. I've moved and cannot find that piece of info. Nothing I've tried has worked. Is there a way to "reboot" or bypass the original user and password on a router and start over?
The old network that I had when I left in the fall shows in the wireless list, but it won't allow me to connect. I have internet capability, just not with the router.
Try logging in the router by typing //192.168.1.1 on your web browser. and if it asks for a password usually default username is admin and password is 1234
Posted on Jun 03, 2010
Can i connect new pc to old connection
You simply need to disconnect old computer from the network and connect the new one.
Are you trying to connect wired computer or wireless?
If you are trying to connect a wired computer then you don't need to do anything.
Just take out the Ethernet cable from the old computer and connect it to the new computer.
If you are connecting a wireless computer to the network then make sure that you have all the settings of your wireless router.
If your wireless network is secured then you should know the correct network key.
What is the operating system on your computer?
I will suggest you a website " The Router Setup " which may help you connect your new computer to the old wireless network.
May 17, 2012 | D-Link AirPlus DI-524 Wireless Router
My old d-link router works fine. I bought a new DIR-615 but it won't connect. My computer won't "see" it. I followed all directions several times.
Make sure that the broadcast SSID in your router is enabled. Try setting it up again and make sure all necessary settings are set, or it might be the settings in your computer itself, let me know what type of computer you are currently using so i can check.
Jul 03, 2011 | D-Link DIR-615 Wireless Router
I bought a new N300 today, and am having trouble connecting my old wg111v3 adapter for my old desktop (my new laptop works fine). I named the new wireless network the same as the old G network, but I...
Assuming you're using the Netgear Smart Wizard software, go to your settings screen and delete all the profiles. After that, create a new one and put in the settings for your NEW network, then save it.
May 10, 2011 | NetGear WG111 802.11g/b Wireless Adapter
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    Recently upgraded DSL speed which required new modem (Q1000, Actiontec) which in turn stopped xbox live from getting a connection with older wireless router, bought the microsoft wireless N which is stated...
    I gather from reading this that you have another router that is connected to the Actiontec. The Xbox connects to the other router. You need to check the settings on the other router and the modem to see if the DHCP is enabled, also check to see what the subnet is set to. Make sure they all match. Then check those settings on the x-box.
    Nov 13, 2017 | Microsoft Wireless Network Adapter Xbox...
    I cannot find my WEP key on Router N with Belkin.
    You changed the network key.
    Make sure that you will connect your computer to the router with the cable to change the wireless settings of the router.
    Do not change the wireless settings of the router using the wireless computer.
    open the set up page of the router and check the wireless settings.
    Change the name of the wireless network also.
    create a new network and try to connect to the new wireless network.]
    I think you did not change the name of the network and your computer might be trying to connect to the same old network name with the old settings.
    Click here for more information about router and networking.
    May 02, 2010 | Belkin F5D9231-4 Router
    Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
    Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
    Nov 12, 2009 | Linksys Wireless-G Broadband Router
    Help set up wireless router
    It's better to connect a computer using a cable when configuring a router. establish a wired connection first before running wireless to make sure that the router has been configured.
    1. connect your computer to any of the LAN ports of the router
    2. Connect your modem to the WAN or Internet port of the router
    3. restart your computer
    4. Type http://192.168.0.1 in your browser's URL interface.
    5. go to connection setting and select the type of connection required by your ISP then save the settings.
    Jun 24, 2009 | D-Link DI 514 Wireless Router (DI-514)
    Can't get my laptop to find router
    Yes, go to my network places, right click, select properties, then create new connection, the wizard will walk you through, don't forget you have to put in the type of encryption and the Key ,that may be why it's not working. When you set up your new connection, you can select home/office etc, also delete the old connection, as that will cause you problems.
    Mar 08, 2009 | Linksys Wireless-G Broadband Router
    I'm replacing a Linksys BEFW11S4 router with a newer Linksys model WRT160N. What do I need to do to uninstall the old one, if anything. Do I need to delete all my current connections? Thanks, Mike
    It should not require any changes - since you're going from Linksys to Linksys, the IP address of the router is the same (I believe). So shut down your computer (one with a wired connection to the router!), unplug the old router, unplug your modem, plug in the modem and wait until the lights settle down, plug in the new router and wait until the lights settle down, boot up your computer and wait until it's fully booted. Open a command prompt (Start Menu/Run/cmd) and type ipconfig /all - see if you have an IP address assigned in the range of 192.168.1.x . If so, open up a browser and see if you can access 192.168.1.1; it should demand a login, use your new router's default login (in the manual) and make the changes you want (including a new password!) - change the name of your wireless network, set up security, etc. As long as you make your SSID and security identical to what you had on the old router, it shouldn't require any configuration changes on the computers (though it may require a reboot to make them see the router properly after the changeover).
    Jun 19, 2008 | Computers & Internet
    D-Link AirPlus DI-524 Wireless Router Logo
    172 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
