Question about KitchenAid Refrigerators
Hello. I have a kitchenaid ksbs25fjbl01 that is about 8 years old and the ice maker has stopped making ice. The door mechanism works perfectly dispensing water and ice, it is the maker itself that does not seem to be functioning. There are frozen cubes sitting in the maker waiting to drop into the bin, and the on/off bar is on, but nothing happens. Any suggestions?
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
Richie_asg1
  • 1036 Answers
SOURCE: ice dispenser in door clogged up or frozen
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
Posted on Jun 11, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
SOURCE: KitchenAid Superba ice maker not dispensing ice
the problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
Posted on Oct 31, 2008
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
94 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
