Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Sound god but no picture - Panasonic VIERA TH-65PV500 65 in. Plasma Television
    President:
  • 1,099 Answers
You most likely have a backlight issue with this TV set. Could be the inverter circuits for the backlights. The inverter is the power supply source for the backlights. there could also be a screen driver problem. This would entail changing the entire board. You should call in an authorized LG repair center to check this set out for you. Good Luck and please let me know what you found out about this TV set.
Posted on Jun 03, 2010
  • 4,234 Answers
First of all this is a plasma set and there is no "backlight". The problem is more than likely the high voltage supply. This is not a DIY repair in most cases. The power supply board can be repaired or replaced. At this point, I would suggest that you get a detailed repair estimate from a local shop. We can then provide you with parts estimates for the board replacement should that be the best option for a DIY solution.
Dan
Sony rm892 remote
go to www.fitness.manualsonline.com or www. retrevo.com and download for free.
God bless you
Jul 04, 2013 | Sony RM-892 Remote Control
I have a JVC model av-2799s that still has a great picture but the sound went very soft and it will not change, is the TV done?
test the sound with the following steps ,see the b.diagram:tuner+
,video detector+video amplifier sound i-f +sound DET+audio amplifier+speaker.
God bless you.
Oct 17, 2012 | JVC Televison & Video
NO PICTURE
1) you must test the section Hvoltage, rectifiver, flyback, in order to Get Raster.
see the block diagram attached.
God bless you
Jul 06, 2012 | Sanyo Televison & Video
No picture on my philips 42PFL7422D/137 lcd I have already replaced both master and slave boards and my picture returned. After about a month or two the tv started to make a high pitch whistling sound...
do you have sound but no pix?its the video board if you have neither it will be the board where your coax and audio inputs connect...just a matter of getting the right boards off of e-bay GOD bless
Sep 18, 2017 | Philips 42PFL7422D 42 in. LCD TV
Our Hitachi42 inch television about five years old haslost the picture. Still have sound.
it means the projector is not working or try to replace the picture tuve if then came up with it.god bless
Apr 04, 2011 | Hitachi 50V710 50" Rear Projection...
The tv clicks on but no picture or sound
Hi if your tv is a DLP or LCD RPTV most likely it's a ballast issue which is the board that powers the lamp.It could also be your lamp if tv is between 2-4 yrs.God bless you!
Oct 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Sound but no picture in sony vega projection tv
Hi,if your tv is between 2-4 yrs and you don't hear any strange noises it might be time to replace the lamp.This will be the lamp you need: XL5200 The Original is made by Philips and it's the best lamp in the market.You can find it on discount-mechant .Good luck and God bless you!
Oct 01, 2009 | Sony KDS55A2000 55" HDTV
60" SXRD
Boss U have a bad picture tube.. need to see an expert/ dealer.. have to replace it.. god..it shall be a coslty affair for you.. but thats the only way..
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
We have sound, but no picture
We had the same problem on our Samsung LNS4692. Call manufactures 800# there is a replacement part and they will send out the repair person. if under warranty no charge. No warranty can cost $600+. God Luck. Don't let them try to get out of fixing it.
May 08, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Pink picture with wavy green and blue lines
start with convergence ic's probably stk 392-130 big black chip's on an alluminum heat sink. mark ALL connections with majic marker. check for bad solder connections. for god's sake be carefull
Oct 19, 2006 | Sony KP-53S65 53" Rear Projection...
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
511 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
