Question about Hayward Pool & Spa
I have an error code on my heater stating the vaccum blower switch if i jump the 2 blue wires together the heater ignites and the error code goes off I changed out the vacuum blower switch still having the same problem i see both wires are coming frrom the circuit board does this mean the circuit board needs to be replaced
    Genius:
  • 1,416 Answers
Hello
what this simple means is that the code is an indication of a circuit board water temperature sensor error. There is a chance that there is a loose wire connection on the heater temperature
however,the circuit indicates that the heater temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
All this explanation is to show you what your heater have pass through
before it went bad
it need a replacement
thank you and thanks for using fixya.
Posted on Jun 03, 2010
No ignition
Restart the unit as soon as you see the inducer fan on jump the 2 wires the pressure switch. Your burner should stay on and go through it sequences. If it go through it that pressure switch need replace and make sure your inducer pull under the vaccum of the pressure switch.
Feb 04, 2014 | Goodman GMS90703BXA Heater
1983 Chevrolet C10 Silverado: The AC compressor and heater blower motor fan will not come on.
The brown wire at the speed switch is the power wire. Powers is then directed to the blower motor resistor throught the orange, lt blue and yellows wires. The blower motor receives power through the orange wire. Check for power at the fuse with the key on. If there is no power the problem could be the ignition switch or the wiring in between the switch and the fuse block
Apr 05, 2013 | Cars & Trucks
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
2002 kia spectra color code ignition switch diagram pdf
PART COLOR LOCATION 12 VOLT CONSTANT WHITE/BLACK (+) and WHITE (+) IGNITION SWITCH HARNESS STARTER RED (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 YELLOW (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLUE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 GREEN (+) IGNITION SWITCH HARNESS
Dec 27, 2011 | 2002 Kia Spectra
Radio wires what colors are what?
Below is the layout you requested:
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) IGNITION SWITCH HARNESS STARTER YELLOW (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) LIGHT BLUE (-) @ HEADLIGHT SWITCH PARKING LIGHTS ( + ) PURPLE (+) or BROWN/WHITE (+) @ FUSE BOX POWER LOCK WHITE (TYPE B) @ BACK of FUSEBOX, ETACS, See NOTE *1 POWER UNLOCK LIGHT BLUE (TYPE B) @ BACK of FUSEBOX, ETACS, See NOTE *1 DOOR TRIGGER YELLOW (-) IN DRIVERS KICK PANEL or ETACS, See NOTE *1 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay TRUNK RELEASE BLUE (+), Requires Part #775 Relay IN DRIVERS KICK PANEL SLIDING POWER DOOR N/A HORN YELLOW (-) @ STEERING COLUMN HARNESS TACH WHITE (-) @ ECM, See NOTE *2 WAIT TO START LIGHT N/A BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL
Mar 24, 2011 | 2002 Kia Optima
The heater is showing me ac, and is not letting my heater to light up
its either a bad vaccum switch that is closed and cant open or its a ignition control module or (fenwall) not sending power for it to open open panel and slide down cover there is two round black saucer looking switches replace them or jump them by connecting wire to both leads bypassing the switch if heater turns on need vaccum switch if not ignition control module
Jan 24, 2011 | Hayward 400fdn Low Nox Nat Gas Swimming...
Looking to put remote start and bypass module in 2007 saturn vue need wiring diagram
12 VOLT CONSTANT ORANGE (+) IGNITION SWITCH HARNESS STARTER YELLOW(+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK(+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE LIGHT GREEN (-) See NOTE *1 IGNITION SWITCH HARNESS PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) BROWN (+) @ BCM, PIN B10, GRAY 24-PIN PLUG, See NOTE *2 POWER LOCK RED/BLACK (TYPE A) @ BCM, PIN A8, 16-PIN GRAY PLUG, See NOTE *2 POWER UNLOCK ORANGE/BLACK (TYPE A) @ BCM, PIN A7, 16-PIN GRAY PLUG, See NOTE *2 LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS DOOR TRIGGER See NOTE *3 @ BCM, PINK 24-PIN PLUG, See NOTE *2 8957_VUE_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf DOMELIGHT SUPERVISION WHITE (-) @ BCM, PINK 24-PIN PLUG, PIN A1, See NOTE *2 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK (-) @ BCM, PIN B2, PINK 24-PIN PLUG, See NOTE *2 TACH ANY WIRE NOT PINK or RED @ IGNITION COIL WAIT TO START LIGHT N/A BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DISARMS with FACTORY REMOTE ONLY ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
Feb 27, 2010 | 2007 Saturn VUE FWD 4
I have E04 error code, fan runs but no ignition or gas or gas smell
troubleshot vaccum switch determined it was operational (Use Pentair's website for service instructions on the switch) Fan speed too slow due to worn out motor. Replacing blower assembly
Aug 01, 2009 | Pentair Minimax NT Heater
I need electrical plan for pluging my radio ,for toyota echo 2005
If you are attempting to install an aftermarket radio Don't butcher the plugs on your Toyota ... simply go to a car stereo shop and buy an adapter plug for $10-$20 then wire it to your new radio ... then just plug them together (the wires on the adapter are marked) You'll likely need a dash kit too ... save yourself from a lot of frustration time and money! ....
May 08, 2009 | 2005 Toyota ECHO
My heater turns on the gas starts but then it shuts down
Try to locate the red and white wires either behind your thermostat or on the furnace itself. Jump them out and see if the furnace stays on. If you do it at the furnace you will need to hold the door switch down. If it runs fine, you have found your problem (the thermostat) if it goes out again, the furnace will display a number of blinks on the circuit board. Look on the reverse side of the furnace access door and there should be an Error Code chart to get you started figuring where to look next.
Nov 10, 2008 | Goodman GMS90703BXA Heater
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
