Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
I have a Sta rite model PLD50 pump and DE filter system. After adding the media, the pressure is good at 12-13 psi for 30 mins. to an hour and then starts to climb toward 20 psi. All the while the discharge stream is diminishing from very strong to very weak. I can turn off the pump for a few seconds and everything returns to normal. Then the cycle starts again. I suspect the cartridge is not seating well over the check valve and it is becoming clogged with DE or the valve is sticking. I've taking the filter apart 3 times, hosed off the media, re-assembled and re-coated the cartridge with the same result. Bad valve, bad cartidge? I'm frustrated.
  • 106 Answers
Sounds like the cartridge either needs to be acid washed or replaced. Just hosing it off won't do it. To see if it needs an acid wash just put a few drops of muriatic acid on the cartridge after you hose it down. If it bubbles up, then it needs it. Let it soak in a bucket with acid mixed with water. Some pros just pour acid on the cartridge directly, but thats kind of dangerous.
Posted on Jun 03, 2010
I got a new crtridge filter, runs for bout 2 hours, lost return to a minimum, and pressure up to 150. bought a second one thought first filter was bad and same problem, ive been washing this filieter out...
make sure when cleaning filters you use TSP first mix with waster and rinse filter with it then let sit 5 min then rinse off then clean with filter cleaner then rinse
Jul 08, 2011 | Sta Rite StaRite PLM Series Modular Media...
Looking for manual on Sta Rite Sand filter Model HRP830
Here is a copy of the users manual for Sta Rite BRPB30 pool filters.
http://www.pool-filters.com/pdf/Sta-Rite-HRPB-Filter-Manual.pdf
Apr 16, 2011 | Sta Rite Sta - Rite 31" Sand Filter & 1.5...
High Pressure: STARITE 1.5 hp pump designed to
It is a cartridge issue in my opinion. I dont recommend cartridges ... Sand is so much superior as a filter medial. If this is an option for you ... I recommend it. If not an option, you might be able to get a different type cartridge that will filter at a lower rate and not get as dirty as fast ...
Jul 31, 2010 | Sta Rite Max E Pro 1 12 Hp Up Rate...
Pool pump inflow/outflow handles and their position?
GO TO YOUR LOCAL POOL STORE AND SEE IF THEY HAVE A SIMILAR UNIT . IF THE FLOW IS NOT GOOD YOU MAY NEED A NEW DIFFUSER $20... .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
I have a sta-rite mpra6g pump with a new filter, when the impeller broke fixed it after algae problem have cleaned continuously after properly adding chemicals. I have noticed pump pressure has gone up to...
When the pressure gos up, it means there is a restriction in the discharge side of the pump. The pump making 30 psi means the pump is doing its job. The filter side is the problem.
Jul 05, 2009 | RTO 680 GPH Swimming Pool Filter Pump
PRESSURE RUNNING TOO HIGH
Most filters are rated to 50 psi..although 35 does seem high. make sure that all of your returns are open..could be a valve, or have some other kind of blockage. Although rare, check valves can get stuck closed, so check them, too.. If you have a white one that is solid get rid of it and get one that you can see into..jandy for instance...
Just as a rule I always install a bypass on any heater or heatpump. It will increace the life of the heat exchanger by years.......
Mar 23, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
390 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
