Question about Xerox Phaser 7300DN Laser Printer
Cyan toner misalignment
Cyan toner prints about 1/8th inch off
  • Anonymous Mar 16, 2014
    The printer is using the cyan toner in stead of the black toner in the print
    President:
  • 2,072 Answers
That is an issue called a regicon adjustment that is off.
You really have to have a laptop hooked up and the regicon set up. May need the laser kicked a few knotches to get it back in alignment.
The setup itself tells you how many clicks to move the laser.
Posted on Apr 09, 2008
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
THE PAPER SELECT ARE NOT COMPATABLE, SELECT LGL IS EQUAL TO 8.5/14 FLSC IS EQUAL TO 8.5 /13. TRY TO SELECT BLACK COLOR OR CLEAN YOUR DEVELOPING UNIT.
Feb 06, 2014 | Canon imageCLASS D880 All-In-One Laser...
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
Excess cyan toner is on electrostatic transfer sheet even after wiping it. All black and white pages are printed with cyan background.I am even using original cartridges.
Since you have Cyan toner in places where it should not be then the only possible cause is a defective Cyan Toner cartridge. I worked on one just last week where the customer complained about Magenta toner on their prints. I also noticed Magenta toner on the Transfer Belt just as you see Cyan toner on the Transfer Belt. I replaced the Magenta Toner Cartridge and everything cleared up nicely. The Transfer Belt Unit can also cause similar problems but it would not be ONLY one color like Cyan. It would be a mixture of all colors. My bet is replace the Cyan toner and you will be fine. If you have an old empty one just shake it up a bit and try it as well. This might allow you to verify before buying a new cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 06, 2011 | HP Color LaserJet 2600n Printer
Copier is printing cyan toner streaks across the top 4 inches of the page
open front cover, move toner catch tray out of the way, you will see 4 green levers or knobs. Pull them in and out 3 times each. This cleans your corona's. There should be a sticker inside the door to show you how to do this.
If this doesn't help, you have problems with your cyan drum, or transfer rollers.
Thanks!
Ryan
Oct 27, 2010 | Sharp MX-2300N Color Copier
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Apr 26, 2008 | Dell 5110cn Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
148 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
