Question about Whirlpool Duet GHW9150P Front Load Washer
Code F35 washer will not empty or cycle properly. Stops w/ F35 code flashing
    Genius:
  • 1,416 Answers
Hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Posted on Jun 03, 2010
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
    F35 is a water level error.
    The water level switch (pressure switch) has malfunctioned.
    If you remove the top panel, three screws in the back, you will have access to the pressure switch.
    With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
    If the fault codes return after doing this, you will likely need to replace the pressure switch.
    Also - please be sure to use He soap.
    Thanks for using FixYa!!
    Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
    My 2 yr old kenmore high efficiency washer flashes F35 and stops. i have to unplug it and start it over, wasting detergent
    this is a pressure swtich failure code and possible caused by to many suds.you should try and run the unit empty with no soap on the quick wash cycle this will help clean out any soap left over in the system.
    If this continues to happen replace the pressure switch this is located under the lid and has a small rubber clear or black huse running to it.also good prevent maint.is to clean the drain pump area and coin cathch if it has one over time things will build up in the pump area and can cause a pump malfunction.
    Nov 10, 2010 | Kenmore HE2 Plus Front Load Washer
    Code F35 on Kenmore Elite HE5t front loader washer.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
    Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite front load washer stops and blinks F35 and locks up
    f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
    Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
    What is code F35 on a whirlpool washer model wfw9600twoo
    It's a general code for some electrical system problem. Ours flashes "SUD" before while the machine is on before flashing "F35" when it stops. I've tracked this done to being a problem with the pressure sensor switch in ours, and it appears to be either from obstruction from too many suds (like using the wrong detergent), or an actual sensor problem. I followed online advice to pull the tube and blow back to clear any suds out, and that cleared it for one cycle, but then the problem came back, so I'm either going to try some other things to clear before calling for a service person to replace the sensor. The part is W10156252 Switch, Analog Pressure Sensor, number 20 of the washer parts diagram.
    Jul 29, 2009 | Whirlpool Washing Machines
    Error code F35
    May 18, 2009 | Kenmore HE2 Plus Front Load Washer
    The washer beeped--I thought the cycle was
    Apr 27, 2009 | Kenmore Elite 45986 Front Load Washer
    My whirlpool washer flashes f35
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
    Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Sears Kenmore HE3 Error Code F35
    Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    762 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
