My Washer , Model #WHDSR209D5WW is not functioning properly The water just keep on filling up and if I don't turn it off, it would run over.It happened once and the floor was flooded.
  • 5,911 Answers
Sounds like this could be a pressure switch problem. The switch is located inside the operator console behind the water level selector knob. It is a white disc-shaped device with an air hose and electrical connector attached. The first thing to do is inspect to ensure the air hose has no holes and has not come off the switch. Trace the hose from the switch, all the way to where it connects to the wash tub. Sometimes the hose will work itself loose or get a crack or small hole in it somewhere and the switch will no longer shut off when its supposed to. If the hose is intact, I would recommend replacing the switch. Searspartsdirect.com carries the part. Just type in your model number and look for item #10 under the "Controls and Backsplash" heading. The part number is WH12X10076 and costs about $62. I hope this info helps you.
PS To get the knob off, there is a small plastic retaining clip behind the knob that must be pulled out, before the knob will slide off the shaft.
Posted on Apr 09, 2008
Thanks. I had the same problem. Followed your instructions to access the pressure switch and hose. Cleaned the air line w/ 5% vinegar and air pressure (I blew through the line). The problem appears to be solved.
I appreciate the simple and accurate instructions
Posted on Mar 23, 2009
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
The water does not shut off even after it reaches the proper level it continues to run and it overfills and leaks out the bottom of the washer the clear hose is not clogged and we blow into it we can hear...
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 14, 2009 | GE WVSR1060A Top Load Washer
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Washing machine won't spin or aggatate
We had the same problem and it was really easy to fix. On the dial for the load size, turn it all the way to the right to "reset" and then check to see if it resolves the problem. It did with our washer same model and problem. Best wishes.... Doug
Jun 08, 2009 | GE Washing Machines
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
430 people viewed this question
Top Washing Machines Experts
