Xerox 8550 showing error code 11,009.46:31197 how do i fix it without paying extortionate xerox callout
    President:
  • 2,072 Answers
  • Check that all system grounds are secured.
  • Check or reseat all connections to the Electronics Module.
  • Check the condition of all harnesses.
  • If the problem persists, follow the procedure below.
  • Check ground integrity for the printer.
    Does the error persist?
    Go to Step 2.
    Complete.
    Reseat all system interconnections and check that the cables are properly dressed.
    Go to Step 3.
    Complete.
    Reset NVRAM.
    Locate the error code below.
    Complete.
    For errors 11, 001.47 and 11,017.45
    Replace the Tray Lift Motor.
    Replace the Electronics Module ( REP 5.0.5).
    Complete.
    For errors 11,002.48 and 11, 016.44
    Check the Option Tray connection.
    Replace the optional tray.
    Complete.
    For errors 11,003.49 and 11,0014.42
    Replace the I/O Board ( REP 5.0.13)
    Complete.
    For errors 11,004.41 and 11,013.41
    Replace the I/O Board ( REP 5.0.13).
    Replace the Control Panel ( REP 1.0.9).
    Complete.
    For errors 11,006.43 and 11,015.43
    Replace the Printhead ( REP 2.0.2).
    Complete.
    For error 11,009.46
    Complete.
    For all other 11,000.4x errors:
    Complete.
Posted on Apr 14, 2008
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Xerox 8850 error code LL-12
I expect you have this fixed by now.
Look closely in the fuser area, perhaps you might see the problem.
Are both fuser rods working correctly one rod has the coils in the middle and the other has them either side so as to even out the fuser temperature. You might need a meter to answer this.
This would need Xerox engineer callout.
Good Luck
Jul 18, 2014 | Xerox 8850 Led Printer
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Printer Phaser 8400 : error 07,010.43:116034
If your printer is networked, if can fix its self by accessing this site
http://www.phasersmart.com/
May 18, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Mar 31, 2009 | Xerox Phaser 8550DP Printer
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Apr 22, 2008 | Xerox Phaser 8550DX Laser Printer
Phaser 8550 cyan doesn't print
If you go to the Xerox.com site and click support and drivers. enter phaser 8550 and there is a printhead update you need to get, You have to fill out a form.
That may be your problem since there is no fault code.
Apr 13, 2008 | Xerox Phaser 8550DX Laser Printer
Error code for 8550
Call Xerox, they have a problem with this code and the ink loader needs to be updated.
It has to do with the yellow sicks loading properly
Oct 31, 2007 | Xerox Phaser 8550DX Laser Printer
698 people viewed this question
