Question about McCulloch Garden
When running my chainsaw chain comes off. - McCulloch Garden
  • 59 Answers
Maybe the chain isn't tight enough, Not that it should be tight but with a gentle pull away from the guide bar the "roots" of the chain should not come clear of the groove in the bar.
The chain should not be too tight but so long as the chain runs freely, which you can check by rotating the chain by hand, then it w should run OK.
Don't forget, always keep the chain perfectly sharp as a blunt chain causes wear and tear on the machine and makes the work a lot harder for the operator.
Posted on Jun 03, 2010
Oil not coming out on the bar
Check chain oil reservoir, assuming it is full and pathways are clear, your oil pump might be toast , or not set up properly. Usually, there is an adjusting screw. Don't run it dry.
Mar 12, 2014 | Homelite Gas, 16 In. Bar, 38 CC, Chain...
Ake 40 18s chain keeps coming off when in use
The only time I saw this was when the saw was run with the chain too loose. The chain should be snug al the way around the bar. If it is run loose for too long the chain will develop burs on the driver links. Now the driver link will not fit in the groove on the bar so the chain is tossed off. Replace with a new chain
Aug 31, 2013 | Bosch AKE 40-19 S Electric Chainsaw
As the chain stretches for McCulloch chainsaw Titan 7
a couple things will cause a chain to stretch running it to tight running low on oil a dull chain over heats it
Sep 20, 2012 | Garden
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Sep 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
Chain keeps coming off bar
The chain only comes off the bar if, the chain has become lose and de railed, or if the timber you are cutting is very springy and you are trapping it in the cut, our twisting it in the cut, if the saw is not oiling the chain correctly it will stretch and if not addressed will come off, once it has come off the drive links are usually damaged, you should realy start again with a new chain, when running close to a clean peice of wood you should a steady stream of chain oil coming from the end of the guide bar.
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
The chainsaw runs fine chain rotates all ok untill pressure is applied to cut through a small branch. the chain then comes to a stop and sometimes the engine will stall???
The engine should 4-stroke lightly when running at speed unloaded, but immediately 2-stroke when cutting. Adjust the H jet CCW somewhat to accomplish this. Make sure the chain is being oiled properly, the chain tension is correct, and the chain is sharpened properly. If this doesn't help, then remove the bar and chain, and wash out the clutch internals with spray carburetor cleaner to remove excess oil. Hope this helps!
Jan 11, 2011 | Echo Garden
My chainsaw does not cut although the chin is brand new, the direction of chain is correct also.
If the chain is turning, it has to cut. Make sure the cutting edge of the teeth are coming toward you on the lower run of chain. Good luck!
Nov 22, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I can start up the chainsaw, but chain doesn't spin
Is the chain brake on? Pull the lever your knuckles are against toward you to unlock the anti-kickback brake.
Jun 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fixing the chain back onto a Ryobi chainsaw
pull the barcover and bar off and you will see the clutch put the chain back on the clutch and put the bar back on and run the chain down the bar and put the cover back on and you will see a little screw in the bar cover are in front of saw by bar tighten that screw until slack is out of chain then tighten bar nuts.
Apr 04, 2009 | Garden
Replace bar and or chain ...saw runs but not with the chain
The bar MUST be straight. Soak the chain with penetrating oil. If that doesn't free it up, replace it. If it is kinked sideways--replace it. Never run a chainsaw with damaged parts.
Feb 02, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
125 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
