RCA F32650 32" TV Logo
Posted on Jun 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1st) No Sound, Good Picture. 2) Good Sound, No Picture
At first, there was no sound but the picture was looking fine. I turned off both the television and the DVR box. When I turned both back on, the opposite happened: now the sound is working fine but there is no picture. However, the televisions channel still appears in the corner and the volume bar will appear when the volume is changed. Anyone have any idea?
Francisco Mauricio G
Level 3:
Genius:
  • RCA Master 1,551 Answers
  • Posted on Jun 03, 2010
RCA Master
Level 3:
Genius:
Answers
1551
Questions
Helped
525429
Points
4192
Memory eeprom corrupted
My vizio model# E480-B2 was working fine one day and the next when I turned it on I have no picture.. Perfect sound ! Does anyone have any ideas?
Hi , The link below is a YouTube page full of videos showing how to fix a Vizio television NO picture GOOD sound, I hope this helps....... CHEERS..
Vizio Tv With No Picture Good Sound YouTube
SANYO Model CLT2054 Television
sounds a lot like you lost the video driver or control board functionality. From the 'decay' of your image, with sound still working, and all else being good, you're primed for a new video controller. Are you inclined to do the repair yourself? The service manuals are hard to get online, but the local service center MIGHT sell you one.
Have a samsung lcd 46"....turns on fine and picture looks good but no sound. I have checked the mute and also have checked that sound is turned on from the menu. Also checked to make sure no head phon
the main board will need replacement. Audio signal are produced on the main board so replacing the main board should solve the issue. You can get replacement main boards from www.tvcircuitboards.com
2helpful
Philips 40PFL3705D/F7 turns on with sound no picture was fine the night before
looking online as i have same problem, sound without picture points to T CON board. approx $50-100 part + labor
1helpful
No picture on screen
Is the TV under warranty? If it is don't muck around, contact them straight away as you have a electronic problem with your screen.
Before that make sure the yellow chord is in the visual port and red and white into sound. 2) If thats all good try an experiment, as you know the sound is good, use one of the sound cables to replace the yellow. Is there a picture now? If so replace chord, if not make contact to exchange for warranty.
No Sound on Toshiba 57H81 projection TV. Picture is fine.
The sound amplifier IC has went bad and needs replaced. Call a good TV Tech.
Check with the BBB 1st before you decide on one.
2answers
Picture good but no sound on my Hitachi model 50ex20b
Your audio switch on the back may have gotten moved please check the switch
93helpful
3answers
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
2answers
1998 50" Rear Projection Hitachi Model #50SBX70B--NO picture
can you see the g2 from crt sound like you list your g2 from
the flyback.i need m# plz
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
