Question about Keurig B60 Coffee Maker
My coffee maker is now setting off the GFI. We've
My coffee maker is 3 years old, but is now setting off the GFI. We've tried replacing the GFI 15 amps with a 20 amp GFIs but it still goes off. When I plug it into a regular outlet, it works just fine and doesn't set off any breakers. I'm not sure what the problem is. Someone suggested it may be arcing and I shouldn't leave it plugged in without suppervision. I have other appliances already plugged into the GFIs and the only thing setting them off is the Keurig coffee maker. What can be happening? Should I buy a new one?
rickzilla
  • 706 Answers
SOURCE: Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Posted on Aug 31, 2008
HIRAM517
  • 59 Answers
SOURCE: tripping the GFI
CHECK SPOUT LEVEL MIGHT NOT BE RETURNING TO IT`S PROPER POSITION
Posted on Aug 20, 2009
  • 30 Answers
SOURCE: Keurig coffee maker causes kitchen electricity to short out.
I'm not completely certain what the problem is because it's not displaying your whole subject (it get's cut off after electricity to...). However, if it is solving the problem by moving it out of the kitchen, it's likely that the problem that the circuit is overloaded. Coffee makers have a large current draw, as do many other kitchen appliances. If you plug too many of them into the same circiut and then turn them on, you will put too high a drain on the circuit and it will cause the the current to become unreliable and then, eventually, through the braker or blow the fuse to protect the wiring in the wall (to keep it from catching fire). If this is the case, you need an electrician to run another circuit or remove some appliances from your kitchen.
Posted on Sep 18, 2009
espressonist
  • 1711 Answers
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: We have had our Keurig
Sorry to read about your problem, I hope this helps you out.
It sounds like you unit has a major malfunction. and they do break
Keurig does not make repair's or carries replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Testimonial: "Thanks for the immediate response. I will contact Customer Service at the telephone no. you gave me. Hope I get a good response from them. "
GE UNDER COUNTER ICEMAKER HAS BEEN GREAT FOR THREE YEARS, NOW POPS THE GFI DURING CYCLE. TECH SAYS IT SHOULD NOT BE ON GFI CIRCUIT.WHY IS SO AFTER THREE YEARS/
Good chance your Gfi is on verge of failure I had one, took long time for me, yes me to figure it out. Replacement may solve problem. Double check, have you added other appliances on the same circuit? GFI will pop when other appliances are on the same circuit. For example two coffee makers on same time same GFI and similar issues. Otherwise may have a problem with the ice maker voltage leaking somewhere. If GFI replacement doesn't help. Do you still have warranty on Icemaker? If so follow that. If not contact Ge anyway. Recalls maybe "hidden".
Feb 27, 2015 | GE Refrigerators
Seacoast magic plus keeps tripping gfi breaker
try in different GFI outlet, if it trips the new one, the coffee maker is dangerous and you should return/replace it, it has a short.
if it doesn't, replace the GFI outlet, it is old.
Apr 16, 2012 | Philips Coffee Makers & Espresso Machines
How to fix a bunn coffee maker that trips a gfi
Every time I plug in my bunn coffee maker, it trips the GFI. But when I plug it into another plug in my kitchen, it will work, but it seems like the water reserve is not right. It blows too much steam and the top starts lifting up from the pressure of the steam, then it starts leaking out the top left side. Then if I pour enough water to make 10 cups, it only makes 6 or 8. The coffee maker is only 3 years old, what should I do?
Aug 01, 2010 | Bunn NHB Coffee Maker
Gfi in kitchen blows when pluggung in coffee maker
either gfi is on an overloaded circut or the gfi is bad....the heater on a coffee maker uses alot of amps / you may wanna try a different plug
Jan 03, 2010 | Bunn BTX 10-Cup Coffee Maker
GFi breaker blows
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Apr 23, 2009 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Aug 30, 2008 | Keurig B60 Coffee Maker
Waring pro wc1000
Try plugging it into another GFI outlet. If it still trips, it's a problem with the coffee maker wiring and is cheaper to replace it than fit it.
Aug 25, 2008 | Waring Pro WC1000 Coffee Maker
Briel Sintrac cofee/express machine
I all ways have a good coffe(express)until now.Sems to me to much water and the coffe is no good
What can i do?
May 27, 2008 | Coffee Makers & Espresso Machines
WC1000 GFI
You're not alone.  Same problem here.  Breakaway power cord on my Waring deep frier burnt to a crisp.  Don't known about you, but I'll never buy Waring products again.
Oct 03, 2007 | Waring Pro WC1000 Coffee Maker
Keurig B60 Coffee Maker Logo
52 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
