Cannot control water level. Water spills over washer. Agitator not working. Spin cycle does work.
  • mam8321 Apr 10, 2008
    I did as you suggested and the washer still does not work. The controls will not advance the the desired setting.
    Genius:
  • 1,073 Answers
Replace the pressure hose that attaches to the pressure switch and goes to the outside of the washher tub, it has a hole or crack in it somewhere
Posted on Apr 10, 2008
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
Agitator starts before water fills. When adjusting
There may actually be more than one setting on the diaphragm control, or you may two diaphragms each with their own setting control. I hope this helps you! Good luck!
Dec 29, 2009 | Washing Machines
Kenmore Model 110.26712693 stuck on agitator cycle
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
Agitator wont spin
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Agitator not spinning
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
Jun 22, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
