Question about LG 22" FLATRON LCD Monitor
Vertical line on a lcd monitor - LG 22" FLATRON LCD Monitor
  • 787 Answers
If it's present on all screens (for example, even when booting up the computer) then try a hard reset. If that fails, you need to have it checked by a technician.
Posted on Jun 03, 2010
Vertical line in monitor
theres no way to fix vertical line on lcd the only way is to replaced lcd panel with same panel type
Feb 28, 2014 | Philips 17" LCD Monitor
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
Vertical lines in the monitor
Vertical lines from the top to the bottom of the screen are due to failing T-CON board (part of the LCD panel assembly). You can try reseating the ribbon cable attached to the T-CON board, otherwise new screen will be needed, these failures are due to cheaply made screen by company such as Chi Mei. It willget worst with more lines.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Jun 04, 2010 | Acer AL1715 17" LCD Monitor
Two vertical 1'' white lines on right side of Lcd panel
If the lines are parmanent, Then suspected part is LCD Panel.
Dec 27, 2009 | Samsung 226BW Monitor
Vertical lines on lcd how can i fix it works perfect with ext monitor and i did bios update and it help some?
Restart the Computer and access the BIOS and check if the vertical lines are visible. If the vertical lines are visible in the BIOS then the issue is with the LCD screen itself and may require service. This is confirmed when an external monitor works fine. If the issue is related to the video card of the Computer then the lines should also appear on the external monitor which is not the case.
Oct 24, 2009 | Dell Latitude C600 Lcd LCD Display
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
I have vertical colorful lines on the screen just got a new computer with windows vista
the monitor is bad if your getting vertical lines on it. Anytime you get vertical lines on any monitor, LCD, laptop LCD, etc, then that means the screen is bad.
Your monitor needs to be replaced.
Aug 09, 2009 | Envision Computers & Internet
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
LG 22" FLATRON LCD Monitor Logo
291 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
