Question about Panasonic NV-DS55B Mini DV Digital Camcorder
Panasonic NV-DS55 My camcorder has suddenly stopped workong with error mesage F02. When turned on the camera light flashes fo few seconds and turns off. can you help
  • hangie May 16, 2017
    I just fixed a virtually unused Panasonic NV-DS55B with the F02 error. The problem was just bad connections from the mechanism sensors to the main board, so that the main board was detecting a S-reel error and thought that the reel was not rotating when you could see that it actually was. Once the connections to the mech. were cleaned and tightened-up the camera worked as new.
    Dave Williamson.
  • 4 Answers
Try to restthe setting by default setting and try to take out tape if is there inside.
Posted on May 05, 2008
There is a flashing red and then shut down NV-DS65
battery is not charged or is defectived. or the power supply is not working.
i suggest replacing the battery or getting a new power cord
Apr 23, 2009 | Panasonic NV-DS65 Mini DV Digital...
Panasonic Nv-EX3 - Error F02
I have just had the same problem and I have just charged my battery, taken out the tape, switched the camera off and when switched back on and re-entered the tape everything is working. Hope this helps.
Dec 18, 2008 | Panasonic NV-EX3EN Mini DV Digital...
I have the same camera and just had a warner F02 code on my screen and the red light flashed twice. I have just taken out my tape and switched off then switched back on and all the functions are working. Hope this helps.
Oct 06, 2008 | Panasonic NV-EX3EN Mini DV Digital...
Flashing red light and working
i have NV-D60EN model panasonic mini dv camer but when i use to record and play back, its red light falshing for about some second later switching itself off. it does not function any thing so that if you don't mid give me the solution please
yours respectful customer
God bless you !!
May 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
Panasonic NV-GS50 - Display indicates "To Service"
This means you need to get it serviced, because it has detected a fault or error.
Sep 06, 2017 | Panasonic NV-GS50 Mini DV Digital...
F02 error in Panasonic vedio camera
F02 error code means tape slack. If you have a separate deck try winding the tape all the way to the end and then rewind it back to get the tension up. Or if you are able to do it in the camcorder then do it this way.
Nov 30, 2007 | Panasonic NV-VX77 Camcorder
Power Light Flashing
Jun 26, 2007 | Panasonic NV-DS29B Mini DV Digital...
Panasonic nv-ds55
It sounds like the sensor is going bad. Here is the manual for the NV-DS 60, which is very similar to yours. You may need to take it to a repair shop. Good luck.
Dec 10, 2017 | Panasonic NV-DS55B Mini DV Digital...
it is general fault in this camcorder get a clean path tape and you may get better work regards
Apr 25, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Error F01 and F02
Both of these error codes are related to the reels inside of the camcorder. The error codes that you mention stand for No Take Up Reel Rotation (F01) and No Supply Reel Rotation (F02). The take up reel is the one that pulls in the extra slack while the tape is running so that the tape itself does not become loose and choppy. The supply reel is the reel in charge of turning to allow the tape to unwind. What you are experiencing are both common reel rotation errors.
First things first, restore your camcorder to factory settings, take out the battery and leave it out over night, plug it back in the next morning. If that doesn't fix it, try a completely different tape that you've used in the camcorder before to see if there is something wrong with the tape reels (sometimes they are loose) or the tape itself.
If that does not work, your next step is cleaning the camcorder. Use a cleaning tape. You may want to perform two or three cleanings in order to make sure that the camcorder is back to normal. You can also use an electronics dusting brush and manually clean out any visible dirt or dust, sometimes blowing cool air (such as the canned air used to clean computer keyboards) directly into the camera can fix the problem as well.
Unfortunately, if neither of these solutions fixes it, it's time to take it to a repair shop, it may need a new reel mechanism inside of the camcorder.
Mar 30, 2017 | Panasonic PV-DV710 Camcorder
Panasonic NV-DS55B Mini DV Digital Camcorder Logo
512 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
