Question about Swanson S0107 "Big 12" Die - Cast Aluminum 12" Speed Square
I just bought a Swanson 12" Speed Square model S0107. How do I put it together? What are the parts for? I know how to use a standard square but this one has a sliding bar and wing nuts and Hex barrel nuts? How do I assemble it and what are the extra parts for?
3 Suggested Answers
  • 142 Answers
SOURCE: need to know how to figure a rafter cut
Assuming you already know the angle you require, take the edge with the level on it(if you have that model) or the side that hangs over and hook it on the edge of the board. If you look at the top, on the 90 degree end, it says "pivot", and that is where you will spin the square around. You read on the 45 degree end that was hooked to the board for you angle. If you are trying to cut a rafter at a specific pitch such as a 6/12 you will spin the square around until the 6 on the Common scale lines up with the edge of the board. The Hip/Val scale is for cutting hips and valleys for the roof structure.
If you have any other questions, feel free to contact me here
Bob
Posted on Sep 19, 2009
  • 288 Answers
SOURCE: Need to calibrate my dw708 sliding compound miter
i use a framing square off of the back fence with the blade down. when it is square, i check the other side of the fence and loosen the screws on the plate with the degree increments and set it to zero
Posted on Dec 23, 2009
How to calculate square feet I have l44 inches wide and 214 inches long.
nobody does maths any more?
12 inches equals 1 foot
144" is 12 feet
214" is 17.83 feet, so say 18 feet.
To work out area in square feet, just multiply the two together.
12 x 18 is 216 square feet.
Aug 12, 2017 | Home
How many square foot of floor panels do I need to cover a room 12 foot x 6 inches x 13 feet in square eet?
To convert your 2 dimensions to square feet you have to multiply them together.
12.5 x 13 = 162.5 square feet.
You do not give the size of floor panels you want to use
To find out how many panels you neeed, divide 162.5 by the square footage of the panel
eg, 12" x 12" panels are (1x1) 1 square foot so you would need 162.5 of them.
24" x 24" panels are (2x2) 4 square foot so you would need 41panels
Aug 15, 2015 | Building Materials
Why is a speed square 7 inches ?
Hi Joe,
Yes it is 7" X 7". I offer two videos to enjoy its usefulness. Extreme How To Original Swanson Speed Square
Here is a stair layout 12" X 12" with attachments Swanson Big 12 Speed Square . I prefer stair gauges and a layout square. Either method s good.
Here is the link for a variety of topics and input on the uses of the squares for your library.
Fare. Well. Swanson Big 12 Speed Square for Stringers
Dec 31, 2014 | Office Equipment & Supplies
When I try to cut a 45 it seems to be cutting a little more than a 45. how do I adjust it?
Make sure the blade is 90 deg vertical to the saw table. Make sure the indicator is set approprately. Raise the blade just enough to clear the table/base. Place a swanson speed square against the fence and blade. Make sure the indicator is at 90 degrees. Here you might want to tilt the square and check that the complete blade is flush against the sqaure as high up as possible. Lay the square back flat on the table and pull the blade toward you as much as possible. The teeth on the blade should ride against the square extented completely out.
Now set the square against the fence with the 45 degree angle coming away from the table and set the blade on the 45 deg mark on the insicator scale.
The blade should touch the square all the way out fully extented.
Or just experiment with some scrap and check
May 19, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Need to know how to figure a rafter cut
Bob
Sep 11, 2009 | Swanson Speedlite Level Square
KNOWING RISE OVER RUN HOW DO I USE THE SQUARE TO MAKE MY ANGLE?
Run is alway 12".
Example 4" (rise)/12" (run)
Measure 4" on one leg of the square and 12" on the other leg. Connect the points and there your angle.
Jun 29, 2009 | Swanson 119 High Visibility Speed Square
I need help with puzzle 100
There are 28 PINS -- Count each PIN starting from left to right on each line. (1 -- 28)
Square ( 1) Join together Pin No's ( 1 -- 2 -- 6 -- 7 )
Square ( 2) Join together Pin No's ( 4 -- 12 -- 21 -- 27 )
Square ( 3) Join " " " ( 5 -- 9 -- 11 -- 15 )
Square ( 4) " " " " ( 3 -- 10 -- 13 -- 19 )
Square ( 5) " " " " ( 8 -- 16 -- 23 -- 28 )
Square ( 6) " " " " (14 -- 18-- 20 -- 25 )
Square ( 7) " " " " (17 -- 22 - 24 -- 26 )
GOOD LUCK.........
Apr 12, 2009 | Nintendo Professor Layton & the Curious...
ProTech Drill Press
Sounds like you already have it figured out. Drill a round hole first then use a small square file to make the correct sized square. Depending on what the sheared piece looked like, you can find some square stock at the hardware store.
Oct 25, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Swanson S0107 "Big 12" Die - Cast Aluminum 12" Speed Square Logo
244 people viewed this question
Top Swanson Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Swanson Measuring Tool and Sensor Expert? Answer questions, earn points and help others
