Question about Ricoh Aficio CL7000 Laser Printer
My Ricoh CL7000 multi-function printer/copier/... reports an SC545 error. The unit will not proceed until error is corrected. Seems to be a fuser unit related issue - will replacing the fuser unit correct and reset error?
  • jim4686 Jun 03, 2010
    HI
    My Ricoh CL7100 Printer/copier/... unit is showing an SC545 error message. I can't clear this message so unit is completely down. From brief review - it looks as though this error is fuser unit related though I can't say that with certainty. Can you verify the error is related to the fuser unit and if so, is replacing the fuser unit with a Ricoh Fuser Unit kit likely to solve this error.
    Thanks
    President:
  • 1,194 Answers
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser’s thermistors help regulate the temperature of the fuser assembly. The fuser assembly is the part that melts the toner onto the page.
Try this:-
1.- Turn Off the printer.
2.- Press "ONLINE and SCAPE" buttons..
3.- without stopping pressing them (ONLINE and SCAPE) TURN ON THE PRINTER.. and wait about 10-15 seconds and Service menu show up.. after this.. release the buttons...
4.- Go to.. Engine Maintenance... Enter..
5.- Search for SP5810 (Fusing err clr) and Enter.
6.- Accept the change and enter
7.- Turn off the printer
8.- Finally turn on the printer and try to print something
If this does not solve your problem, you will need to take your device to Ricoh service center for repair.
Thanks for using Fixya.
Good Luck and have a nice day.
Posted on Jun 03, 2010
  • jim4686 Jun 04, 2010
    Good Morning
    Thanks for your insight on the fuser unit. re: your suggestion for reseting the machine, my unit is a multi-function unit. The operator control pamel on the printer itself is essentially non-functional - instead, the functions of the control panel you mentioned are performed on a supplemental panel that's integrated with the unit's scanner. Do you have any insights on the controls I should use on that panel to reset the unit.
    Thanks,
    Jim
  • Ranglo
    Ranglo Jun 04, 2010
    Turn off your printer. Remove all connections and all the components (drivers) of your printer from your computer. Turn off your computer. Now after some time 1-2 hours later, turn it opn, reinstall all the components and now connect your printer.
    Guru:
  • 302 Answers
If you are sure that it is a Fuser related issue. Then replcing the whole unit will most probably solve your problem. Also try to remove and re insert your current fuser unit and check it out. their is always a slim chance that it may work for some time again.
  • Mohsin Idrees
    Mohsin Idrees Jun 03, 2010
    The SC545 error stands for "Fuser overheat error", "Fuser ready temperature abnormal" and "Hot roller ready temperature abnormal". so surely your fuser is faulty and as i said replacing it will solve your problem.
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Dec 17, 2009 | Ricoh Aficio CL7000 Laser Printer
How do I top up the fuser oil on a Ricoh CL7000 printer does not seem to be anything in the maintenance manual
You don't. The Type 7000G Maintenence Kit is the self contained oiler unit, rated for approximately 30,000 prints on 8 1/2" x 11" stock. If a person were to try to "top off" the oil, where would said person locate the correct type of fuser oil. Not all fuser oil is the same, viscousity wise as well as chemical composition. What an expensive mess.
Sep 11, 2009 | Ricoh Aficio CL7000 Laser Printer
CL7000 Replace fuser unit type G error
Run SP7-804-9
If you don't know how, or what that is, then you'd better call a service depot.
I will not post or discuss service mode procedures with end users, because you can create a great deal of problems if you're unsure what you are doing. (No offence)
Jun 17, 2009 | Ricoh Aficio CL7000 Laser Printer
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
Error code sc545
That's a fuser warm up error. Likely either a blown fuse, lamp or thermistor. Fuser is usually replaced as an assembly, and code can only be reset in "service mode" after the cause is fixed.
Mar 14, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL7100
THe oil unit is not entered correctly
Feb 22, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL7000 Pink bands
Hi there you have the magenta drum cleaning fault. You will have to replace the Magenta PCU (Photo Conductor Unit) 99.5% sure
Thanks J
Nov 15, 2006 | Ricoh CL7000 DT2 Laser Printer
Ricoh Aficio CL7000 Laser Printer Logo
126 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
