Question about HP Compaq nx6110 PC Laptop
My hp nx6110 don't get power either from the battery or the charger
    Scholar:
  • 62 Answers
Do this first, remove battery and charger, press and hold down power button for 10 seconds it will drain the power from the system esp the static electricity, then put the battery and charger back,
> if still no go, check for indicator lights on the charger, if your charger does not have indicator lights, try it on another system to check that it's not the charger that is having problem
> Possible that the battery is already drained and the charger is having problem, so if teh charger is working on another system and not in yours there is a problem on your computer
> You can also try turning on system with just the charger
> If another system is not available to try the charger get local help because problem might be on the mianboard.
Posted on Jun 04, 2010
Hp notebook Nx6110 having following problems (1) When it is powered on sometimes it fails to start and gives msg NON SYSTEM DISK OR DISK ERROR ...PRESS ANY KEY TO CONTINUE (2) its bluetooth device...
I will first try to restore the system first to the point when you had no such problems.
Then, run anti virus program like kaspersky. (Some programs catche virus or spyware well but don't fix well.)
If your problem stays same, there are two possible problems. (hightly possible first)
1) Motherboard Problem. (If your notebook were shut down due to any electric shock like sudden power down)
2) Power Problem. (Short power) - example bad battery
I hope it helps.
May 26, 2011 | HP Compaq nx6110 PC Laptop
Hp nx 6110 was working fine but suddenly it went off and now it does not boot
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP Compaq nx6110 PC Laptop
Power on password has been changed can't get in to laptop (compaq nx6110) Thanks for any advice
try taking out the cmos battery and putting it in again, that should reset the system password
>it is the big watch like battery inside the laptop
Oct 29, 2010 | HP Compaq nx6110 Notebook
Hello, I am having problems with my Compaq nx6110 laptop not charging. It is not the battery, as I replaced it at the end of December. The problem seems to be that the charge isn't reaching the battery,...
If you remove the battery, does the AC Adapter power the computer? Does the laptop have a barrel type power connector? I have replaced several power connectors for broken center pin. Does wiggling the power connector affect the charging light?
Mar 20, 2010 | HP Compaq nx6110 Notebook
I have HP compaq nx6110 laptop with fogoten BIOS password what should i do?
You will need to:
  1. Turn off the laptop.
  2. Remove the battery.
    Remove the two screws that secure the keyboard.
  3. Remove the keyboard.
  4. Remove the battery "RTC".
  5. Leave it in this state for 15 minutes.
    Then connect only the main power cable WITHOUT the battery installed.
  6. Power on the laptop, and the RESET is done.
    Power off the laptop.
  7. Reconnect the “RTC”.
  8. Re install the keyboard.
  9. Re install the battery.
  10. Make sure there are no spare screws.
  11. Power up the laptop and continue to use.
Sep 09, 2009 | HP Compaq nx6110 PC Laptop
Compaq nx6110 problem
check your laptop by another charger, so u can find the exact problem, sometime charger problem may also occur.
Note: change your charger
regards
ehsanullah
Jun 17, 2009 | HP Compaq nx6110 Notebook
Please I need help. I was using my Hp laptop to play music when it went off and refuse to restart. I removed the battery and re-inserted it again but it still refuse to start then I observed that there was...
Sounds to me like you need a new battery. There are a couple of other things it could be (i.e. the ac power cord) but it is most likely a battery-related issue.
Mar 09, 2009 | HP Compaq nx6110 PC Laptop
Power on Password
You need to remove the RTC battery from the laptop for 5 minutes.
The service manual at the attached link shows how.
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00502970/c00502970.pdf
Sep 01, 2008 | HP Compaq nx6110 PC Laptop
Battery cant power my nx6110
This is normally caused by a fault either within the battery or the system board. I'd be inclined to take the back off and reseat the board and cables before you start replacing stuff unless you can borrow another battery from somewhere.
May 24, 2008 | HP Compaq nx6310 Notebook
HP Compaq nx6110 PC Laptop Logo
190 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
