Question about eMachines eMD620-5133 Notebook
My emachine d620 laptop will not power on. the led light is green and the battery is charged. the power button is not working.
    Novelist:
  • 162 Answers
Hi. I would suggest that you powerdrain your computer might fix this. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. If this doesnt work try to powerdrain again the laptop then just use the ac adapter to turn on your computer and that is without the battery. Hope this helps.
Posted on Jun 03, 2010
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Dell latitude D620 battery does not charge
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 07, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Emachines D620 laptop swtich on with no display.. cpu fan runs for 2 seconds and to switch on the laptop i have to take off charger and battery
Remove the main battery and charger from the laptop, press and hold power for 60 seconds, if this fails the motherboard has major issues and should be checked by a technician.
Jun 10, 2012 | eMachines D620 Laptop
Need to open an emachine D620 to access the inside.
ther are screws everywhere that you will have to find, you should google your problem untill you get the help your looking for
Apr 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
Feb 04, 2010 | Dell Latitude D620 Notebook
This a probelm with recharging the battery
Possibility is that your laptop's adapter's output is no longer capable of supplying enough power to charge the battery & operate the laptop simultaneously. Please try a replacement adapter & check if it resolves your problem.
Another possibility:
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 28, 2009 | Acer Computers & Internet
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Problem with emachine m5124 startup
Take the battery out and unplug the power cord. Press down the power button continuously for a solid 30 seconds without stopping. This drains all the power out of the circuits and resets whatever invalid state your computer is in.
Now, leave the battery out but plug in the AC and turn on the laptop. If it works, turn it off again and insert the battery. All should be well.
Jan 25, 2009 | E-Machines eMachines Desktop PC
Dell d620 will not go into charge mode
This is usually caused by a bad battery. Sounds like both batteries are not working properly. They may still hold some charge, but they are wearing out. After all, they are batteries, and bateries wear out. Keep in mind that some batteries are better than others, even though they may be the same brand, some will hold a charge longer, and some wear out faster. I'm on my second new battery in a year and a half on my Dell, the first held a great charge but wore out after approx 8 months, the one I'm using now still charges fine but only last about an hour and 15 mins.
Jun 21, 2008 | Dell Latitude D620 Notebook
BATTERY PROBLEMS?
Hi
Latitude D620 battery module has a battery charge tester. First remove the battery or turn the laptop over and press the battery icon and the note the battery LED indication.
If there is no LEDs lite, shut down the laptop, connected the power Adaptor, install the battery and check if the battery charge LED lites up.
If it doesn't double check the power Adaptor. Latitude D620 is rated to use a 90W Adaptor. There is a 60W Adaptor (looks very similar to) but this is for other Latitudes and AMD Vostro systems.
If the Adaptor has the correct rating, then check below for more info;
1) [Very Likely] The battery may be faulty or end-of-life and needs replacing. Check the battery connector on the Latitude and battery itself for any broken or bent pins or bits.
2) [Possible] You have the wrong power Adaptor or the Adaptor is faulty. This however would not explain why the battery is undetected.
Start up the Latitude into System BIOS (F2). Under System > Battery information check the battery and AC Adaptor status
If the Latitude D620 has warranty you may open a warranty claim with Dell Support.
Mike
Apr 02, 2008 | Dell Latitude D620 Notebook
eMachines eMD620-5133 Notebook Logo
1,288 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
