Question about SATO CX400 Thermal Label Printer
WANT PRN FILE FOR BARCODE LABEL DESIGN
HOE TO DESIGN A PRN FILE FOR ZEBRA TLP 2844
Posted on May 10, 2012
3 Suggested Answers
  • 97 Answers
SOURCE: z4m printer problem
You may have an element or two on the left side of the printhead that is worn out and not printing. The best way to see if elements are not working is to use the widest label you have and run the PAUSE test. Turn the printer off, press and hold the PAUSE key while you turn the printer on. Keep pressing for about 10 seconds and then you can let go. When the printer is finished starting up, a test pattern will print. Part of the pattern is a black box. Any elements that are not working will show as white vertical lines. The only way to correct is to replace the printhead.
Hope that helps !
Posted on Jun 09, 2010
TLMC2020
  • 16 Answers
SOURCE: Need label file
Hello Mr.balamurugan
I think you are asking about printer consumables. Like Barcode Labels or Pre-Printed ones.
First thing, you need to buy the labels from the direct labels manufacutures and avoid buying from the resellers.
We have some common sizes like 50 x 25 or for little big labels like 100 x 50 .
Rates vary depending on the volume,
if you have not purchased the printers, i recommend you to take a look at these printers.
Zebra TLP 2844 - [Click To Preview Brochure] Citizen 621z - [Click To Preview Brochure]
If you require the quote for labels printer or labels. please contact us, or provide us your contact no. so that our sales men can reach you.
Kirubakaran Trridev Labelss Mfg Co www.trridevlabelss.com Mobile 96000 07995 Email : Kirubakaran.rv@gmail.com
Posted on Sep 04, 2010
How to print .prn file
You should have the proper software to send .prn to print.
try downloading from www.nicelabel.cl a Suite version of the software. It's a 3 step setup.
Jun 07, 2014 | SATO CG408 Thermal Label Printer
I require a .prn file for my cx400 for my software support person to design the barcode string to be used for my software to create the barcodes. my barcode printer is Sato CX400 & the software I am...
HI ...
1.I am using Sato CX400.my printer problem is when i give Command for printing copy (default by prn file one copy) but print out two copy and i wastage lots of label .so please help me about my problem.
2. i have sato Cx400 two printer but in both printer font is Bold & another is UN bold.so how make both printer setting same
Please help me by mail (bvionline@yahoo.co.in)
Thanking You
Jun 21, 2011 | SATO CX400 Thermal Label Printer
Z4m printer problem
Hope that helps !
Jun 09, 2010 | Zebra Z4Mplus Label Printer
Currently have a TLP2742 duplicator which prints barcode and text. Need to alter this to just print the text. how do i do it?
Do you know if you are using a label software program to design the label or just ZPL (which is Zebra Programming Language) code direct to the printer? If it is software, then you can open that label design software file and remove the barcode. If it is ZPL, then you need to remove it from the code. I can help with this if you can email me the code.
hilster1968@gmail.com
Jun 26, 2009 | Zebra Eltron TLP 2742 Thermal Label...
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Feb 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Pls help in this VB code, Sato CX400 barcode printer
jst try this u create a label from label printing software using ato font then make a prn
then attach u r vb code in to prn it will work
rohitjain
prn example-------------
A
Z
A
CB+18
Z
A
CD250,3300
Z
A
AR
Z
A
A100950647
Z
A
%2h416v0072BG01031>H23456111
%2PSP02h573v0021L0101XS922
%2PSP02h618v0021L0101XS18K
%2PSP02h415v0089L0101XS17125
%2PSP02h416v0039L0101XSPO124
%2PSP02h416v0022L0101XS215gms
%2PSP02h618v0043L0101XSDR37/0.20
%2PSP02h618v0064L0101XSDR37/0.20
%2PSP02h618v0085L0101XSDT/B44/0.82
Z
vb code example------------------
Open "LPT1" For Output As 1
Do While rs.EOF = False
For I = 1 To Val(Text1.Text)
Print #1, "A"
Print #1, "*&"
Print #1, "Z"
Print #1, "A"
Print #1, "CB+18"
Print #1, "Z"
Print #1, "A"
Print #1, "CD250,3300"
Print #1, "Z"
Print #1, "A"
Print #1, "AR"
Print #1, "Z"
Print #1, "A"
Print #1, "A100950647"
Print #1, "Z"
Print #1, "A"
X = "%2h380v0065BG01031>H"
Y = rs.Fields(6).Value
X = X + Y
Print #1, X
Print #1, "%2PSP02h618v0085L0101XSKT"
Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
Print #1, "%2PSP02h618v0064L0101XSNetWt"
Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
Print #1, "%2PSP02h618v0043L0101XSDiaWt"
Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
Print #1, "%2PSP02h618v0021L0101XSColWt"
Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
Print #1, "%2PSP02h371v0028L0101XS$"
Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
Print #1, "&"
Print #1, "Z"
Print #1, " A"
Print #1, " #E5"
Print #1, " Z"
Print #1, " A"
Print #1, " CS2"
Print #1, " Z"
Print #1, "A"
Print #1, " 0000"
Print #1, "TEXT1.TEXT"
Print #1, "/"
Print #1, "Z"
Feb 04, 2009 | SATO CX400 Thermal Label Printer
Please help abt VB6 code for SATO CX400 printer
just make prn file or by crystal report
call me on 9974985001
Barcode size
Only if you have acces to the software. Are you using a label design program like Zebra Design or Bartender software?
Aug 27, 2008 | Zebra 140XiIII Plus Thermal Label Printer
SATO CX400 Thermal Label Printer Logo
1,256 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
pkwc
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
