Question about Konica Minolta Office Equipment & Supplies
Minolta CSPRO EP 1080 isn't copying, shows only warning lights
My Minolta CSPRO EP 1080 does not make any copies, it shows the warning lights constantly on the display
I have a Minolta 1080 could be used for parts.
jim@solarsystemsintl.com
Posted on Sep 14, 2010
Cspro ep 2030 minolta copying rough in the morning, but okay in the afternoon, solution please
Sounds like the warm up controls are not opperating properly. Or it is in a very cold environment. The "fuser" that provides the heat required to "glue" the toner to the paper may be defective, or the connections to it's controller or the controller is defective. Temporary solution may be to leave it "on" overnight to keep it as warm as it gets in the afternoon. Will take more electricity. But eventually it will need to be repaired, or replaced with a lightly used equivelent. It may be less costly than repair.
May 07, 2015 | Minolta Office Equipment & Supplies
MMY COPY MACHINE IS CSPRO MODEL EP 3010 MINOLTA APER ERROR CODE C061
Lens Motor, under the big glass is to your right is the lens assy. there is a motor that works the mirrors on that side it is either jammed or burned out. Or worse case the board controlling it is bad. You have a Legacy Minolta Machine, get a tech out (Old School one:))
Jun 02, 2014 | Konica Minolta Office Equipment & Supplies
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
I just bought a used EP 2030 CSPRO for my personal Classroom use but when I try to copy it only gives out all black copies. Any idea? Thanks Byron Cowan
Try to copy with the glass cover open, once the scanner moves you should see that the halogen lamp is lighted. If not, either the lamp or the thermal fuse is busted.
Oct 12, 2009 | Minolta Office Equipment & Supplies
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
NO LIGHT NO MOVEMENT INSIDE.
If there is no light coming from the lamp in the scanner and the carriage is not moving this is a serious problem. It could be that the main board is bad. Typically the exposure lamp is just burnt out but if the carriage is not moving something more serious is not working. Just to verify open the document feeder on top and press the start key. You should get an error code if the lamp does not work.
Jan 19, 2009 | Minolta DI-2010F Copier
The copier Minolta CSPRO 2050 shows me call your technicians
Time for a PM on this machine. That's what the maint indicator means. Check the copy count and tell this number to your technician when you talk to him so he can bring with him the required parts and supplies.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
Have a problem with my cspro 1080 coy machine the a red light with the symbol of the copy mchine is on and doesn't want to copy
First make sure that all the doors/ covers are closed --- not just by looking but push on them. Sometimes over time the switch gets pushed in to far and even though the doors/ covers look to be closed the switch is not pushed in far enough. When you find the switch ( should be a little slot that you see silver through, you can bend it out slightly and gently.
Dec 18, 2008 | Minolta EP1083 CS/PRO Copier
475 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
