Amp not working properly.............
Amplifier - Technics SU-x301 only plays everything very quietly - you can only just hear it at full volume but the display screen shows full volume as being 0 dcbs? Was secondhand!
  • 4,234 Answers
Mke sure that the tape monitor switch is turned off.
Dan
Posted on Apr 09, 2008
  • ABRsvcs Apr 09, 2008
    If that fails to resolve the problem, we need to check the outputs. Please update this with your findings and we'll proceed to the next step.
    Dan
  • Olof
    Olof Apr 02, 2016
    The SU-x301 doesn't have a tape monitor switch. Any other ideas? I have the same problem.
Technics 1080 pre amp volume control is not functioning correctly
Technics SE CA1080 Service Manual
there is a chip called an operational amplifier under a heat sink on the pcb,that fails when it get top volumed for two long theres regulators with heatsinks.
it is listed as,
Technics SE -CA1080 amplifier F61 fault,
May 13, 2015 | Technics Audio Players & Recorders
Need a manual for su-x301
http://www.hifiengine.com/hfe_downloads/index.php?technics/technics_su-x301_rs-x301.pdf
Mar 30, 2014 | Technics SH-GE70 Home Equalizer
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
Turntable is playing quiet
Hi, if your not plugged into your amp via a dedicated phiono input, Ie CD or Aux then you need a preamp to boost the line levels. Cheers john. Styluscity
Oct 24, 2012 | Technics Audio Players & Recorders
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Lost left stereo channel from amp. All speakers / wiring ok Technics SU-V6 amplifier. Wondering which component is most likely problem so I can cannibalise another amp.
If at full volume with the balance cutting out the right channel you can hear some music on the left (very weak), then the pre-amp is working and it's the power amp that's gone. Vice-versa if you can't anything, but say hum.
If it is the power amp check out the devices on the heat sink.
Check too for broken or burnt parts too!
Jan 21, 2010 | Audio Players & Recorders
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
299 people viewed this question
 Grubhead
Grubhead
