Question about Seagate Notebook Hard Drives: 40GB (ST94011A) 9.5mm 5400RPM 2MB Notebook Hard Drive (DMST94011A)
Slave is ok but master freezes...
Hi,I mostly used my st94011A-40gb seagate momentus hdd as external drive.But next time when I plugged it into my laptop as normal hdd,I realized that as master hdd the laptop freezes,but when I plug it as slave,than the computer recognizes my hdd but the problem is that as slave,I cant install windows to it because it doesnt have a boot support than...
Now the only thing that I can do is to start the computer from a usb stick with a linux distro and use the hdd as storage media...
I checked hdd for bad sector but its clean...
I thing the controller card of hdd is problem,is it easy to fix,or is there anyway to install xp even if the hdd is in slave mod?
thanks
  • mefairo Jun 03, 2010
    dear chiefmecha,As I wrote,The hard drive doesnt work in my laptop as master mode or cable select mode.If I connect it as master,my laptop doesnt start,it freezes,only in slave mod my laptop starts normal,recognizes the hdd,but at slave mod windows is not able to boot from hard drive...
  • 600 Answers
You can install even if it is a slave disk. also you can try setting the jumpers to master mode, check the sides of the hdd, it has a jumper setting and set it to master, using the shorting pin, just plug it out and connect it to the right setting
Posted on Jun 03, 2010
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
I have placed this hdd into an external case to use as a portable drive but when i plug it in to my laptop (mac book pro) it starts to beep. Windows is installed on the portable drive i was hoping to plug...
at ATA hard drive there is no master or slave, if you want to make it master connect it at ATA slot 1 at mother board, and if you want to make slave connect it at ATA 2 at motherboard
i hope this helpfull
Jan 19, 2011 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Seagate HDD 40GB doesn't support by the Asus board.
not true, check your HDD configuration. especially the master, slave et.c jumpers..
Regards
Feb 24, 2010 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Laptop won't boot. HDD does not spin
Hello
I am very sorry to say, your drive is done..
Just google click of death, you will see what i mean.
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 24, 2009 | Seagate Momentus 5400.3 ST9120822A - 120GB...
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Dual seagate hd on pl 2506 controller, only one drive detected.
yes it does matter what second one is jumpe dto it must be slave on middle of ide cable end of cable master one slave on sec drive do it
Oct 12, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
May 21, 2008 | ASUS K8V-MX Motherboard
HDD not detected
plz try in another pc, if the problem remains then you contact the vendor
Apr 23, 2008 | Seagate Notebook Hard Drives: 40GB...
Usb not working
What does USB have to do with this drive? Is it external?
If not, did you set the Master/Slave jumper on the back correctly?
Geno
Feb 16, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Seagate Notebook Hard Drives: 40GB (ST94011A) 9.5mm 5400RPM 2MB Notebook Hard Drive (DMST94011A) Logo
162 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
