Question about Whirlpool ED2FHSS Side by Side Refrigerator
Kenmore side by side refrigerator. Condenser fan
Kenmore side by side refrigerator. Condenser fan runs constantly. Refrigerator and freezer compartments appear to cool normally.
I DONT HAVE A CONDENSER FAN FOR MY FRIDGEDAIRE SIDE BY SIDE REFRIGERATOR. I'm using a regular fan. How can i purchase one
Posted on Jul 22, 2013
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
dididsaythat
  • 291 Answers
SOURCE: refrigerator repairs
check freezer for frost build up on back wall and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Posted on Sep 04, 2007
dididsaythat
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
SOURCE: Kenmore Elite Side by Side refrigerator not cooling enough
it could be either gas problem or may be compressor is not working
Posted on May 14, 2009
Runs almost constant.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Kenmore Side by Side Refrigerator
Freezer not cooling properly. The compressor comes on the fan is constantantly running and cold air is coming through the vent in the freezer the meat etc freezes but not as solid as before
heatman101
Jun 29, 2011 | Kenmore 63014 Top Freezer Refrigerator
Hi, I have a GE side by side GSS23LSTA refrigerator The last few days it has been running constantly. The refrigerator side temperature is fine at 35 degrees, but the freezer temp is staying at around 12...
Hi Mark and welcome to FixYa, I am Kelly
Touch the front of the unit where the doors close and feel if it is very very warm to the touch. If it is very warm to the touch... here are the prime suspects:
1. condenser coils covered in lint
2. condenser fan not running or running slow.
An easy way to determine if there is a condenser fan or coil fan problem is to simply direct a floor fan at the base if the refrigerator. If it cools down substantially in an hour.... there is a problem with the coils being clogged or the condenser fan not running. If that makes no difference... before opening the back of the unit... inspect the back wall of the freezer compartment for any signs of ice build up. If you see ice-build up.... unplug the unit.. remove freezer contents and direct that fan into the freezer compartment for just over 2 hours. Then return the unit to normal service.... If the temps come down to normal... for 2 - 3 days then start creeping up again... you have an automatic defrosting problem.
Forgot to mention... make sure the evaporator fan is running at full speed.
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My side by side refrigerator no freezer and no cold condenser fan and evaporator fan are running but compressor normal no warmer,no hot
heatman101
Apr 16, 2011 | Kenmore 55602 / 55604 / 5560 / 655609 Side...
Refrigerator and freezer not cooling fan still
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
afafd
Dec 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Freezer and fridge not cooling well i clean the condenser fan
heatman101
,.f
Mar 13, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator freezer not working
heatman101
ayrh
Nov 27, 2008 | Kenmore 50522 / 50524 Side by Side...
Whirlpool refrigerator side by side door seal very hot
when you said fans working....does it include the condenser fan? or it may have two evaporator fans..
if condenser fan is working, then it is just normal. if the compressor is running, that part would really heat up. and if it is too hot, then the condenser fan could probably not running.
its not constant because the compressor cuts off when ever the thermostat cuts off.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool GC5SHEXNS Side by Side...
Inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Dec 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
264 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
