Question about Panasonic DMR-E75V DVD Player/VCR
Drive not reading and laser making clunking noise even when no disc inserted
    Genius:
  • Panasonic Master
  • 1,550 Answers
Change the dvd sistem entirely
Posted on Jun 03, 2010
The disc drive on my acer Aspire 5742G will not read any music cd's or dvds. I makes plenty of noise as though it is trying to open it but nothing!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
Apr 01, 2012 | Acer Aspire 5742G
DVD writer after loading the disk makes a series of clunking noises as it attempts to read the disk - after about 20-30 seconds it stops and the green light goes out - fails to show up on desk top or in...
May need to clean the laser, or it may be a disc that
drive doesn't read You need specs as to what drive writes to and reads to
Nero info gives this information
Feb 15, 2011 | LaCie (300736U) DVD±RW Burner
Dvd no read error
The 'NoRead' error points to a faulty DVD-RAM drive. If the drive is making clunking/whirring noises, and taking too long to read an inserted disc, chances are the traverse unit (spindle motor/laser assembly) within the drive has failed. Unfortunately, this part cannot be replaced; you would need to replace the whole drive.
Look around for a good cheap used one, or, if you are prepared to do so, order a new drive (brand new DVD-RAM drives ordered through Panasonic could cost a couple of hundred dollars or more though so be warned). Check the model number on the top of the drive (prefixed with VXY before considering any replacement.
Feb 12, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Xbox 360 console can't read disk
If your console has stopped reading discs this can be because the receptors on the back of the drive have overheated and to fix it you will need to send it in or use a good repair guide to do the job.
Nov 25, 2009 | Microsoft Xbox 360 Console
When i insert the discs it fails to read and says open disc
whip down the disc to make sure its clean then if it doesnt work the laser trying to read it is broken
Jul 01, 2009 | Microsoft Xbox 360 Console
KEEP SAYING UNPLAYABLE DISC My xbox 360 keeps reading unplayable discs but if i sit there long enough and keep turning it on and off, it will work. But after doing it for half an hour it gets really...
Sounds like the laser is starting to go bad in your dvd drive if it has to read it a few times before it might see the discs.
The laser is inside of the dvd drive and it looks like this:
http://www.amazon.com/Xbox360-Xbox-360-Drive-Laser-Replacement/dp/B000V78Q9O
Depending on the manufacturer of the drive will depend on the laser you will need to get.
You could also take a can of air in the meantime and blow some into the drive to make sure that there is no dust or dirt on the laser as this could cause that message as well.
May 23, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Ps3 is not reading my discs
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise it goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 27, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Blu Ray drive not working
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise i goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 16, 2009 | Sony PlayStation 3 40GB System
CDs won't play RCA RS2651
I think the laser is mis-aligned or the laser unit needs replacing. If you are able to check this for yourself otherwise find a competant technician. Hope this helps.
Oct 06, 2008 | Audio Players & Recorders
Panasonic DMR-E75V DVD Player/VCR Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
