HP LaserJet M1005 MFP - Scanner Errors 6 and 12 Solution
ISSUE: The scan head may not be in the correct starting position.
Updated firmware is available to resolve the issue.
SOLUTION: Upgrade to newer firmware (version20120831 or newer) available on hp.com Support & Drivers.
Select Drivers & Software, enter the product name/number, select operating system and locate the firmware download.
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
