Question about Xerox Phaser 8560DN Laser Printer
The printer will power on but the screen on the printer says self test complete Initializing and its been stuck there
  • 3 Answers
HELLO
Posted on Jun 03, 2010
HP Designjet 130 not initializing...
If there a jetdirect network card trying removing it and restarting.
Nov 11, 2014 | HP HEWLETT PACKARD Designjet 130 printer...
B720 stuck on initializing
Shut printer off
Press Menu and Online buttons while powering back on
Press enter to format memory
Printer will request to be powered off
Power off and then back on. It should boot past the initializing screen and be fully functional.
Oct 30, 2013 | Oki Electric Industry OKI C710dn - - color...
Microcode fails to load at power on self test (post). stays on WorkIO splash screen as the hard drive fails sounds like it crashed or is stuck ina loop.
The microcode is loaded from CMOS not the hard drive. CMOS also sets up the 40Gb. hard drive for use. Initially has no data or partition tables however; post will not complete if the disk is unavailable. Replace the disk drive and you're Done!
May 13, 2010 | Panasonic WORKiO DP-C262 Printer
Printer runs the self test and then initializing and then stops at "initializing, please wait" and goes no further. has new firmware and good memory???
I have had this problem several times and it was always caused by bad inkcartridges. Try starting up the printer without all cartridges. When printer tells you to place the cartridges put them in and see if you get an error. The cartridge witch causes the error is the "bad guy".
Jan 27, 2010 | HP DesignJet 1050c InkJet Printer
XEROX Phaser 8560MFP won't go past "initializing?"
Disconnect the data cable between the Electronics Module and the Printhead to see if Power On Self Test (POST) gets further, to the point where it displays a system failure code relating to the Printhead being disconnected. If so, replace defective printhead.
Dec 12, 2009 | Xerox Phaser 8560MFP Laser Printer
What do i do when i have error 1200 on my pfrinter.
The error 1200 indicates that the cartridge carrier is stuck inside the printer. Please follow the steps given below:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridges are in the middle, snap them firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
You should then try to self-test the printer. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in and follow these steps:
Next, try this printer self-test by following the steps given below:
1. Press the "Copy" button once.
2. Press the "Options" button 11 times until the screen reads "Maintenance."
3. Press the "Left Arrow(-)" button until the screen reads "Maintenance: Self Test."
4. Press "Select."
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error code 1200 is showing?? help!!
4. Press "Select."
Oct 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Getting error message 1203
4. Press "Select."
Aug 20, 2009 | Lexmark X7170 All-In-One InkJet Printer
Unable to initialized
"Unable to Init" indicates a mechanical error, unless you're able to find a stuck paper or parts of a stuck paper or similar, you'll have to send the unit to service to have it fixed.
Jun 03, 2009 | Brother MFC-5840CN All-In-One InkJet...
Error 1200 indicates paper jamming. No paper is jammed however the cartridge carrier appears to be jammed on the left hand side. I have tried everything I can find but cannot release it. Even uninstalling...
4. Press "Select."
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Xerox Phaser  8560DN Laser Printer Logo
266 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
