Washer discharges water so forcefully, it is backing up. Hose has been changed, and there is air around the standpipe. The drain appears clear as a water flows with a hose at full force. The clean out has been checked and it is clear. I assume there is a a P trap. What is the problem?
  • Anonymous Apr 10, 2009
    same issue WTW5200SQ
    Genius:
  • 1,073 Answers
If the home drain pipe is larger than the washer drain pipe and water is backing up the house stand pipe, the issue is in the house not the washe, you cannot cut down the amount of water that the washer discharges during the pump out cycle, doing so will void your warranty and cause problems with the pump, whitch now are mostly electric and can not stand any backpressure on them
Posted on Apr 10, 2008
F 20 displaying on front load machine
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
You say water comes in and fills up to the bottom of the door before the error appears.
There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
There is a pressure switch and the clear plastic hose may be kinked or even have a small hole in it. One thing to try is to remove the top of the washer and then pull the hose off the pressure switch and blow through it towards the tub to check for obstructions in the air dome.
The drain hose should not be stuck down the standpipe to far. If the drain hose is stuck down the standpipe a siphon action ca occur. This means the water would fill and drain at the same time which might lead to the F20 error.
Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
Post the results along with your complete model number.
Sep 26, 2013 | Washing Machines
All of the water filling my kenmore washer is flooding out bottom
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Hot water comes, but does not fill the Washer, and therefore does not rotate the tumbler. It is a Maytag commercial washer
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
Jan 28, 2009 | Washing Machines
My washer doesn't wash.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
My washer will not fill during the cycle for high agitation
You may have a siphoning problem. Double check your drain hose and make sure it's not shoved down in the standpipe too far. The standpipe is the drain line at the wall. If your drain hose is placed too deep into the standpipe, or if you have the top of the standpipe sealed off, the washer will begin to fill and continue to drain at the same time. The symptom will appear as if the washer is constantly filling. You need to leave an air gap opening around the rim of the standpipe, and the drain hose should only be placed about 4 to 6 inches into the drain line. I hope this helps you. Post back if this is not the problem you are experiencing and I will try to provide you with a better solution. Let me know if you have any questions.
Apr 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Help!
You could have a siphoning problem. This can occur when you have your drain hose shoved down in the standpipe too far, or if there's no air gap where the drain hose enters the standpipe.
The standpipe is the drain line at the wall where your washer drain hose is placed. There should be enough air space around the drain hose to allow air to enter the drain line. Also the end of the drain hose should not be shoved so far down into the standpipe that is resting in the trap where water sits (about 4 to 6 inches is sufficient). If either of these conditions occur the washer will start to fill and then begin siphoning (or draining) water from the tub.
Do not seal the top of the standpipe either. Many consumers seal the pipe in an effort to prevent overflows or odors from escaping from the drain line. This actually causes more harm than good and results in washer drain problems.
I hope this helps you. Please post back if you have any further questions or concerns.
Apr 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water keeps draining
You may be experiencing what is known as "siphoning".  If you have your drain hose shoved too far down in the drain standpipe, or if you have the top of the standpipe opening sealed off, sometimes it creates a vacuum and will cause the washer to drain constantly drain.  You need an air gap in order to prevent this.  Double check your drain hoses for the following:
1. Make sure the hose is only placed in the standpipe about 3 to 4 inches.  If it is sitting so far down in the pipe that it is resting in the trap where all the water is it will siphon.
2. Check the opening around the top of the standpipe where the hose rests.  Makes sure there is still an air gap around the hose.  That is, make sure the hose isn't seated so tight that it seals off the standpipe completely.  This will cause siphoning.
3. Make sure you haven't placed anything around the standpipe opening.  Many people will wrap old towels or wash cloths around the opening in order to prevent overflows and odors coming back up through the pipe.  In doing so, they often inadvertently seal off the standpipe and cause a siphoning problem.
Last of all, the standpipe should be about 36 inches from the floor.  If your drain line is sitting too low it can also cause siphoning issues.
I know I'm keying in on this drain line issue quite a bit here.  There are some other things that can cause water levels in a washer to drop, but you mentioned nothing about any leaks and this is the most common problem.  You will know for sure if you pull the drain hose out of the standpipe and suddenly hear a sucking noise.  This is air being reintroduced through the drain line.  I hope you find this information helpful.
Oct 26, 2007 | Kenmore 93702 Top Load Stacked Washer /...
Dishwasher
Check if any of these is the problem..
1)Drain hose is kinked or house drain is restricted.
Straighten the drain hose to improve water flow to the drain.
2)
Standpipe is too high.
Standpipe must not exceed 96 inches in height.
3)
Drain hose has been taped (or sealed) into the standpipe.
Tape holding the hose in the standpipe should not form a complete seal. The standpipe needs air for proper draining. Remove some of the tape to make an air path.
4)
Drain hose fits too tightly in the standpipe.
There must be an air gap between the drain hose and the standpipe for proper draining. The standpipe needs to be at least 1 1/4 inches in diameter.
Oct 22, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Washer wont fill, keeps draining
If you do not allow an air gap for proper drainage on your drain line, the water will siphon out of the washer as it tries to fill. Double check to make sure: 1. You do not have the washer drain hose placed too far down into the standpipe. 2. You do not have the top of the standpipe sealed off. Placing the hose too far into the standpipe may cause the drain line to be sitting in water in the drain trap, leaving no air gap. Sealing off the top of the standpipe will have the same affect. Remember, you need an air gap for proper drainage. Only place the hose about 3 to 4 inches into the standpipe and the fit should not be tight. That is, there should be an air gap around the drain hose as it sits inside the standpipe. Double check and let me know if this helps.
Sep 10, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machine
Do you have the hose inserted too far down in the drain standpipe? If so, you may have created a situation called "siphoning". You need to have an air gap so the hose will drain properly, and doesn't drain when you don't need it to. If the hose is resting in the trap area of the drain, it stays submerged in water and will siphon the water from the washer as it fills. Another situation that occurs is when consumers try to seal the top of the standpipe to keep odors from coming back up through the drain and/or to prevent overflows. This can also cause siphoning. Just some things to consider. Double check your drain hose and let me know if this helps you.
Aug 02, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
