Question about Samsung Smooth SCH-u350 Cell Phone
How do i keep samsung smooth from pocket dialing?
Pocket dial
  • 903 Answers
Pocket dialing is usually less of an issue with flip phones, but if you are having issues with your SCH-U350 pocket dialing, you can lock the keypad by holding down the zero (0) key for a second or two. A message should come up telling you that the phone has been locked.
Posted on Jul 09, 2010
Metro pcs Samsung admire dials by itself
Download the app Call Confirm. It will act as a failsafe by popping up EVERY TIME SOMETHING IS DIALED and asking "Are you sure you want to call??"
It has totally ended my pocket -dialing problems!
Jul 08, 2012 | Samsung Admire SCH
I am having a samsung champ gt c3303. after launching applications downloaded from internet it shows 'powered by JAVA' then it freezes. while installing applications it says 'downloaded JAR invalid'. not...
The application you are running may not work with the version of Java currently on your phone. You need to refer to your users manual on errors of application faults.
Mar 21, 2011 | Samsung Cell Phones
My samsung sway randomly dialed someone 124 times and dialed starbucks 11 times in the past month why?
If you found about this on your phone bill, someone has cloned your sim card. If you have found about this in your calls registry, you lock your phone when you keep you phone in bag/pocket and/or don't have those two phone numbers in your phone book... I have no idea! In both cases I'd call my mobile operator/provider straight away.
Feb 04, 2011 | Samsung Propel A767 Cell Phone
New phone where is the sims card to go..do not see one..samsung smooth verizon
there isnt one its a verizon wireless cell phone which is cdma technology no sim care they use cell towers not satellite and sim to activate it dial *22899 or *22869
May 19, 2010 | Samsung Smooth SCH-u350 Cell Phone
The side speakerphone button turns on Voice commands with the phone closed. How can I stop the pocket dialing?
As best as I can tell there is no way to turn this off. I have searched high and low, I have actually contemplated manually removing the button from the side of the phone.
Jan 28, 2010 | Samsung Smooth SCH-u350 Cell Phone
Error 734 ..ppp protocol terminated in .Aircel pocket internet
dear Sir,
I have the mobile handset samsung GM S 3310. I am usuing Aircel Pocket internet in this phone. Surfing net is not a problem from the handset , but unable to connect it to my laptop.
Before dial up, it gives :error 734 ..ppp links protocol terminated. Therefore I Can not connect pc to handset as the dial up connection is not established.
Oct 28, 2009 | HTC S710 Smartphone
Hi i have just recieved a pocket watch but cant work out how to adjust the time.
There should be a button on the top that opens the watch, under this is a dial, you lift the dial not the button, there should be a click and the watch will stop, then swivel the dial to set the time.
Dec 24, 2008 | Colibri Colibori Swiss Made Elite Quartz...
Only hot air blowing out of vents
i am a nissan master technition in Wichita Ks. we see this problem frequently. there is an air pocket in your heater core, due to low coolant level. for some resion or another your vehical is consuming coolant (usually head gkt leaking into cyl). and sence the heater core is higher than the radiator, the air pocket gets stuck in the heater core.
wait till the vehical is cooled off, remove radiator cap, install coolant funnel (avalible at any auto parts store). lift front of vehical off the ground (to get the radiator higher than the heater core), fill coolant funnel and start engine. allow vehical to reach opperating tempature and the air pocket will work its way loose. you may need to rev engine to change coolant flow rate in atempts to remove air pocket quicker.
sorry about the spelling
jon
Oct 09, 2008 | 2003 Nissan Altima
Dialing properties (prefix)
Please find a PDF file for download with all this information, above. Download and unpacking instructions: To download the file, simply "click" the desired file or link and select save to disk. Download the file to a known directory on your hard disk drive. For example: c:\Temp Open Windows Explorer and locate the "downloaded file" on your hard disk drive. Use an unpacker program to extract the files to a known location on your hard drive. The shareware WinZip unpacker can be downloaded from http://www.winzip.com To setup the dialing properties on the Toshiba Pocket PC, please do the following steps: Tip on start -> settings choose the "tab" connections tip on connections choose the "tab" dialing Locations tip on the button "Dialing patterns" enter your necessary field parameters Please note: disable the "keyboard" in the dialing Locations screen, otherwise the button Dialing patterns is not visible. Tip: Due to the fact that a prefix to dial with a Handy is not necessary, it is a good idea to set all dialing pattern to "G" , which indicates a local number. If one want to use HCSD or GPRS it is recomended to set this parameters to "G", otherwise dealing will not work.
Sep 08, 2005 | Toshiba e310 Pocket PC
Samsung Smooth SCH-u350 Cell Phone Logo
480 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
