Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Our dryer stopped blowing out warm or hot air. All the buttons still work and cool air still comes. Any suggestions?
    President:
  • 1,194 Answers
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
  • Visually inspect your heating element for any broken or burned areas. The heating element is a coil made from a nickel-chrome alloy, called nichrome.
  • When the burner is operating properly, the flame should be clean and blue.
  • If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
  • If the ignitor doesn’t glow, look for a white or yellowish discoloration, or for a break in the ignitor. If this is something visible, just replace the ignitor.
Good Luck and have a nice day.
Posted on Jun 03, 2010
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
I have a kenmore 110.87561601 dryer, it blows warm air but not hot, is this the norm for it?
Check power at the outlet. If you're not getting the full 240v then it'll come out warm but not hot. Otherwise I would go with the timer.
Oct 01, 2014 | Kenmore Dryers
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
2000 mazda 626 wont blow cold air i have replaced compressor dryer and flushed the system and reinstalled new freon any ideas
There is a valve that stops hot coolant from entering the heater box. It is probably stuck open. murf427
Aug 29, 2012 | 2000 Mazda 626
I have a 2002 Volvo S60 air conditioning problem. Initially, the air conditioner will blow cool/cold air, but when I get in traffic and have to do a lot of stopping and starting the air turns warm. Have...
check to see if your cooling fans are working because when they dont work, your air will blow nice and cold when driving but will be hot air when stopped in traffic.
Jun 15, 2011 | 2002 Volvo S60
A/c stopped working,the clutch still engages, fan blows warm, found no fluid leaks
the air blend door inside the heating / cooling unit that sits under the dash is probably not moving. there is an electric motor and control unit that moves the air blend door (assuming you have the electric dial or push button digital controls. some of these vehicles have a valve that shuts off the antifreeze from cycling through the heater and if it remains open then you would get "not hot" but just warm air.
Apr 26, 2009 | 1999 Infiniti.5 QX4
Maytag electric dryer model mde308dayw not heeting up
CHECK YOUR WALL VENT AND DRYER VENT AND MAKE SURE THEY ARE CLEAR,ALOT OF THE TIME IF BLOCK THEY HOLD THE DAMP HOT AIR IN THE DRYER AND WILL TAKE FOREVER TO DRY,IF NOT THAT IT CAN ONLY BE YOUR HEATER BOX OR HEATER BOX FUSE,IF YOU HAVE A METER YOU CAN CHECK BOTH,LET ME KNOW-MIKE
Dec 06, 2008 | Dryers
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
142 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
