Question about Mitsubishi SE2U Multimedia Projector
How to change fuse in this projector - Mitsubishi SE2U Multimedia Projector
  • 75 Answers
Typically most fuses are close to the power plug input, you will need to remove the case. You then can physically see it and will be able to remove it.
Posted on Jun 05, 2010
How to change fuse
See Service Manual, fuses F7001 (6,3A), F7002 (1,6A), bimetal switch (page 17 - power unit, page 33 - Checking the power unit, page 126 - gray areas of the wiring diagram, fuses F7001, F7002):
http://diagramas.diagramasde.com/otros/XVZ10000.pdf
Apr 13, 2015 | SharpVision XV-Z10000U Multimedia...
How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
hi
this lamp has a small lamp pcb with a chip on it.
have u change the complete module or have just changed the bulb.
if you have just changed the bulb then u have to replace the small fuse on the chip.
this should help to reset the lamp timer!
Apr 07, 2015 | InFocus SP-LAMP-LP9 Projector Lamp for...
My projector is not working. Does not seem to be getting juice.
You say checked cord and power there, might be from leakage, check fuse, check units fuse, but if fuse blown, why? might be just close to usage so just replace, if blows again problem
Jul 29, 2014 | Sony Vph-1271q Superdata Ex Crt Projector
How do you change the fuse on lv-s3 cannon projector
The main fuse is on the power supply unit/section and so you need to remove the main panels to get access to the power supply. Normally if the fuse is blown the chances are that the SMPS- swittch mode power supply - has failed and so you might need to replace or repair if the components failed is within limit.
please check this link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Replace the fuse only with the rated value. Before the projector is opened, the lamp must be safely removed and kept aside, Take all precaution not to touch with bare hands and to replace back into the holder with care.
Oct 06, 2011 | Canon LV-S3U Multimedia Projector
I have an occasional problem with my Hasselblad PCP80 projector. Shortly after switching on the lamp will go out for no apparent reason, but all other controls on the projector work okay. The high...
From my PCP80 Service Manual:
FAULT: The projection lamp is lit for a short moment and then goes out. POSSIBLE CAUSE: 1.The rectifier and lamp change board are out of order. AND/OR: 2.Both triacs turn on. Both lamps are lighted until the automatic circuit breaker is released. MEASURES: 1. Change both boards. 2. Change the triac board.
See Also:
FAULT: The projection lamp does not light. POSSIBLE CAUSE: The automatic circuit breaker has released. MEASURE: Reset the circuit breaker. AND/OR: Fuse F102 has blown. MEASURE: Change the fuse. AND/OR: The rectifier and lamp change board are out of order. MEASURE: Change both boards. AND/OR: The triac board is out of order. MEASURE: Change the board.
Dec 21, 2010 | Hasselblad PCP 80 Slide Projector
Kodak Ektagraphic model B-2 slide projector.- It does not start. I checked the power cable and motor OK but I don't know how to reach and check the thermal fuses. I also don't know how to reach the...
If the motor is "OK" (turning), then it's not a fuse, it's the belt that the motor drives to power the slide change mechanism. There are 2 belts: 1 that drives the fan & one that drives the slide change mechanism.
Nov 02, 2010 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Unit will not turn on at all
if you are not receiving any lights or not powering up at all. I would check the fuse. Typically the fuse is located in the projector near where you plug the power cord. Ck to see if the fuse is good or bad by visual or meter.
Jun 04, 2010 | ViewSonic Precision Pro8100 Projector
PLC-SW30 Multimedia Projector no power
You have a classic temp sensor problem. Its a fail safe on the projector, basically a fuse that bridges the main power cables. Looks like a little pot, With a white ceramic head.
Now what it does, Is the white ceramic head rises as the unit gets hotter, and thus breaks the power circut. All you need to do is, open up the unit, locate the sensor (its mounted next to the lamp on your projector) And push the little white head back down, thus closing the circut, and restoring power supply.
Here is the full repair schematic to guide you. :)
http://yama.co.za/forum/index.php?topic=146.0
Aug 01, 2009 | Sanyo PLC-SW30 Multimedia Projector
How can I change the power supply or fuse on projector?
remove the top, front and rear panels (4 copper screws and 4 silver screws on bottom, 2 silver on back). there are 2 fuses for the power supply. the left board (looking from the rear) is the ac filter board, and has a fuse near the plug. the right board is the power supply/ballast board, and has one fuse near the back center, but it is soldered in. if the fuses are bad, replace only with the same size fuse. to replace the power supply (either board), just remove the screws and plugs and replace with part numbers 510-1908-00 (ac filter) and 520-0143-00 (power supply).
Mar 30, 2009 | InFocus X1 Multimedia Projector
Mitsubishi SE2U Multimedia Projector Logo
139 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
