My desktop computer will not recongize the camnex t850 plugged into the usb port or hub. It's as if it cancels or powers down all my other usb ports. I updated drivers rebooted gained access to other flash drives but as soon as I plug in the mp3 they disappear. I tried my laptop same thing no recognition. It worked the first time as I was able to download music but when I used it the second time to add more music this happened. As soon as I plug it in it starts charging up and then it plays it's little song of pu-ding then pu-dong. Can you help?
Mine did the same exact thing, piece of junk.
Posted on Mar 04, 2011
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
Compatible charging cables for phillips go gear hdd1630/17
Apr 10, 2013 | Philips HDD1630 MP3 Player
I PLUGGED MY MP3 PLAYER INTO MY LAPTOP USB PORT AND IT USED TO WORK NOW IT SAID THE USB DEVICE HAS EXCEEDED ITS POWER LIMITS OF ITS HUB PORT AND WONT WORK NOW
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Sep 05, 2011 | Computers & Internet
I DON'T KNOW WHERE TO PUT THE USB CONNECTOR
If you only have one USB connector then you can purchase an USB hub which may have 4 or more ports (I suggest you get a powered USB hub). Then plug the hub into the computer's USB port and you now have several USB ports.
Jan 04, 2010 | Canon CanoScan 4400F Flatbed Scanner
Anytime I plug something in to the USB port it give a error message that states, Power Surge on the USB port. What can I do to fix this?
The USB device could be drawing more current than the USB port can supply or the USB port may be faulty.
Get a powered USB hub and plug it into your computer's USB port and then plug the USB devices into the powered USB hub.
Aug 16, 2009 | Dell Dimension 3000 PC Desktop
Power surge on hub port message
unplug your mp3 player immediately!! it will fry your mp3 player if you leave it plugged in!! try adjusting the player's settings and seeing if there is somewhere to switch it from '1000mah' to '500mah' or lower. try that. if it still gives the error try a different usb port.
May 26, 2009 | Microsoft Windows XP Home Edition
Power surge on hub port a usb device has exceeded the power limits of its hub port there is nothing connected to my computer
I don't know how old your system might be or how many USB controllers it has on the motherboard, but understand this...
Theoretically, one USB port can support up to 999 "daisy chained" devices.
With that said...the way a USB port is implemented on a motherboard, manufacturers enable two or four ports to be working off of one USB interface. Those ports you see on the front of your computer are most likely connected to just one USB interface on the actual motherboard and that's why you always see computers with USB ports located together in pairs.
With that in mind, you're USB ports are connected to what is referred to as a "hub"(that motherboard interface), which only outputs so much power. If one device or many devices attached to this "hub" exceed the power output of this "hub" then it will either back down to USB 1.1 speeds or it won't function at all. That is why some USB accessories require their own wall adapter, because the USB can't supply all the necessary power for it.
So one of two things has happened, either your USB port is fried or you introduced a new USB item to the "hub" that surpasses the power requirements of what your USB hub can output once you plug in your mp3 player.
You can troubleshoot by unplugging all un-necessary USB equipment and try only that port again. My assumption is that the USB hub is fine but the actual usb port you use might be damaged.
Good luck.
Mar 12, 2009 | Acer Aspire One PC Notebook
I added a 512mb stick to my ibm t30 think pad and one port is bad
You can plug a USB hub into the working USB port on the computer. The USB hub can have several ports so you can plug in several USB devices.
I suggest you get a powered USB hub because if all the devices that you plug into this hub exceeds 500mA then your computer's USB port will stop working because it could not supply enough current.
You will not need to plug in the power adapter into the hub if the device/s do not overload the computer's USB port.
Jan 08, 2009 | IBM ThinkPad T30 2366 Notebook
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Helpp! exceeded the power limits on its hub port?
a simple solution is buy a powered usb hub ( which has an adapter which plugs into the mains) that should solve your problem
Dec 11, 2006 | Nikon Coolpix 5900 Digital Camera
91 people viewed this question
 Grubhead
Grubhead
