Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Microwave works but does not cook (does not heat up). Everything else seems to work properly.
    Genius:
  • 1,416 Answers
what this means is that there have been a disconnection on the wire of the element (heater)
what you need to do to fix up the problem is to unscrew the oven then trace the wire down to the element power point and fix it back to it position
please make sure all form of power supply is OFF when carry out this function
Good lock and thanks for using fixya.
Posted on Jun 03, 2010
  • 25 Answers
Your microwave might be in "Demo Mode" if a "d" appears on the display. Press and hold down the Timer button for five seconds to put it back into normal mode.
Posted on Jun 30, 2010
SOURCE: microwave will not heat
Had the same problem--the timer would even count down. The magnetron fan would not turn on, and the microwave would not heat. Checked out several components, but ended up being just the door latch out of adjustment! Be sure to discharge the capacitor before messing around in there. It keeps a charge even when unplugged. Short out the unused terminal on the capacitor to a screw in the chassis, using a short length of insulated wire.
Posted on Sep 13, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 17, 2007
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Posted on Apr 15, 2008
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
biigg53566
  • 81 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Posted on Jan 03, 2009
Everything on microwave works except it doesn't heat or cook. what is the problem?
IT'S THE MAGNITRON - CHEAPER TO BUY NEW THAN REPLACE - SORRY.
Jan 09, 2013 | Microwave Ovens
Everything works but food does not heat up I have a ge over the range microwave
If everything seems to work, except cooking the food it is probably the magnetron which sells for $100-$150 for the part alone.
Jul 07, 2011 | GE Microwave Ovens
Everything on the microwave seems to be working properly, but it is not heating. The power level button says ho -20??? It lost heating abilities during cooking. Thanks!!!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jan 07, 2011 | Magic Chef CMV1000B Microwave Oven
Unit operates does not heat anything
A defective diode or magnetron can cause the oven to sound differently and not to cook.
Jun 19, 2010 | Whirlpool MH6130XEB/Q Microwave Oven
Does not heat up properly. Seems it lost it's
Assuming the turntable works maybe your magnetron isn't working properly. Cheaper to buy new microwave then to fix it.
Apr 30, 2010 | Kenmore Microwave Ovens
Microwave is not cooking/heating.
sounds like the magnatron they can just go out like a light bulb easier to buy a new microwave hope this helps regards Jim
Apr 13, 2009 | Microwave Ovens
Everything works except the cooking part/no heating/turntable not turning, help!
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
224 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
