Question about Ricoh Aficio 450 Copier
In richo 1045, paper is contineus jam in the upper side of fixing unit
  • Ricoh Master
  • 1,297 Answers
Clean oe change the upper fuser roller,fuser roller cleaning roller and clean the lower pressure(red) roller.
Posted on Jun 05, 2010
Fixya review
This is not a 35mm camera. Please post your question in the copier section
Dec 07, 2013 | Photography
Paper jam at the fixing unit for IR 3530
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Apr 18, 2013 | Canon IMAGERUNNER 3530 Copier
Witch is better Gestetner DSm745 or richo 1045 or richo 2045 any one help me pleas
dsm 745 has more modification than1045 more comfortable less disputes little problem. technicians can see this difference there are more details but i expressed that dsm 745 is recently than 1045 good luck
Jun 27, 2011 | Gestetner DSm745 Black and White Copier
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Richo is200e scanner ADF thinks there is paper in the ADF and asks to clear the originals before trying to scan. We have checked the ADF for paper jam and tried cleaning the unit but it will not clear the...
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Mar 22, 2010 | Ricoh IS200E Flatbed Scanner
Delta City has an ImageRunner 5050N. I have a paper jam. I can't get to it. It seems that there is a part that needs to be pulled out part way before the upper try can be pulled out, but I don't...
hi Rita first you have to open the full unit Fixing/delivery assembly
by pressing the metal green handel to left side after that you have to press and pull the unit Forward to find the jam.
Jan 15, 2010 | Office Equipment & Supplies
After a paper jam, I got a code of SC 541 and copier will not completely turn on.
I am guessing... I had to get my magic ball out to figure out what kind of copier you have... You have a Richo copier? If that is correct you most likely have a problem with the fixing unit.
Nov 01, 2009 | Office Equipment & Supplies
Ricoh 1045 false jam
"Z" is the duplexer as I'm sure you are aware. Have you swung it away from the machine and ALSO lifted up the black guide (with blue handle) to check behind it?
Have you also, just opened the upper cover of the duplex unit on the right side of the machine (without swinging the entire unit away from the machine)? If there is actually no paper stuck in it then there may well be a switch that has become dislodged, and you'll need to call somebody...OR, you could disconnect the duplexer:
Turn off main power (red button), and remove the connector cover for the duplexer (towards back of machine at bottom of duplexer), by removing 1 x phillips screw. Unplug connectors, and turn machine back on. You won't be able to duplex but the machine should work.
Good luck, and please rate my solution
Apr 06, 2009 | Office Equipment & Supplies
Canon imageRunner 3200n paper jam in the fixing unit
Hello sir;pull out fixing unit check out the paper sensor that located at the paper exit side,let it move freely.
Jan 10, 2009 | Canon imageRUNNER C3200 Copier
Richo 1045
Probably cleaning to the mirrors and glasses inside the laser the problem can be solved, but this is a complicated work if you are not technician I recommend to him that she asks for technical service. Also a bad connection of the flat cable can cause this problem. The detector of synchronism defective also since code SC326 is a fault of detection of synchronism.
Jan 07, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
141 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
