Question about Epson Stylus C46 InkJet Printer
Epson printer is flashing a red light - Epson Stylus C46 InkJet Printer
    New Friend:
Where is the protection counter?
Posted on Jun 01, 2013
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Epson C45(Red and Green light flashing alternately)
The waste ink collector pads are getting full and this is a protection indicator.
Either get the machine serviced or it may be cheaper to replace it-[depending where you live]
There are tricks to keep the machine going- but eventually the you will get ink leaking all over the place.
Take a look at www.fixyourownprinter.com
Posted on Dec 26, 2007
SOURCE: Epson C48 red and green lights flashing alternately
Where is the prtinter nappy diapher
Posted on Aug 27, 2008
gwbm
  • 353 Answers
SOURCE: Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Posted on Mar 12, 2009
aicaxz
  • 511 Answers
SOURCE: 2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
U can find resetter (SSC Utility or R265 Adjusment) at indoreset.blogspot.com. Reset the waste ink counter.Good luck.
Posted on May 29, 2009
Green on light flashing red lights on 'E' light flashing other lights flashing
I'm sure you have done this correctly, but look at this Epson link
How do install my ink cartridges for the first time
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Apr 28, 2011 | Epson Office Equipment & Supplies
Have flashing lights from Green to Red with no
Sounds like a maintenace pad problem (every Epson printer has a different set of flashing lights to indicate this "Maintenacne request"- read this link: http://www.epson.com/cgi bin/Store/support/InkPadsForm.jsp
Jun 01, 2010 | Epson Stylus C46 InkJet Printer
2 RED LIGHTS FLASHING CARRAIGE WILL NOT MOVE
On the Epson printer two flashing red lights mean that your printers waste ink tank is full and Epson has locked your printer you need to replace the waste ink pads and then reset your printer using the reset utilities
Mar 08, 2010 | Epson Stylus R265 InkJet Photo Printer
EPSON C60 RED LIGHT FLASHING ON CENTRE BUTTON CANT STOP IT
shellnbarry, As I stated in a previous post the red light flashing means an ink cartrdge is low but not empty. When the red light stays on it means an ink cartridge is empty. You can continue to use the printer until the red light stays on.
Nov 12, 2009 | Epson Stylus C60 InkJet Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
