Question about Life Fitness 95Ti Treadmill 95 Ti
I work on Bagram AFB in Afghanistan and have a 95
I work on Bagram AFB in Afghanistan and have a lifefitness 95 Ti treadmill that the incline motor won't go above 3 degrees. What is the solution to this problem? Please shoot me an e-mail on:
    President:
  • Life Fitness Master
  • 832 Answers
Go To Gymparts.com click on Diagnostics and Repair scroll down you will get in on trouble shooting your problem.
Posted on Jun 03, 2010
E2 error lift error
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You have posted this question in the Stair Climber section, but the error you are listing is a treadmill error code. The following information should help.
Probable Cause A) Incline control error.
B) Insufficient power source.
C) User exceeds weight limit.
D) Unit will not lift.
E) Unit thinks it is always at 0% incline and only lifts up.
F) 3 amp circuit breaker has tripped.
G) CPU board has stuck relay.
H) Lift motor is faulty.
Corrective Action A) Access the incline manual mode in diagnostics by pressing 9, 1, 9, ENTER and then pressing HILL program key. Incline the unit with two people on the unit. B) Ensure treadmill is connected to a dedicated 120V, 20 Amp circuit.
C) Advise user of unit's weight limit of 300lbs (137kg).
D) Perform the lift test procedure by pressing 9, 1, 9, ENTER and then pressing HILL program key.
E) Inspect the home switch for smooth operation and inspect the wiring of the home switch for damage or poor connections. Inspect the lift motor cable connections and for the presence of the suppressor board (should only be 1).
F) Test the circuit breakers and replace if necessary.
G) Replace the CPU board.
H) Replace the lift motor.
LifeFitness 9500 Treadmill Lift Control Error
Jul 31, 2013 | Life Fitness Exercise & Fitness
Heart rate Monitor not working on Life Fitness 95Ti Life Pulse
I would suggest removing your heart rate grips and inspecting the contact leads for rust or any other corrosion. This is very commonly an issue and can be resolved by either cleaning the contacts or simply replacing the parts. Using the following link, and your serial number, you should be able to find the contact grips if you end up needing them.
Repair Parts for LifeFitness 95T 95Ti 95Te Treadmills Midline SPORTSMITH...
Feb 18, 2013 | Life Fitness 95Ti Treadmill 95 Ti
Treadmill 91ti lifefitness is making high pitch noise as belt starts. Is anything wrong.? Should I use the the treadmill with this nose.
No do not use, until YOU LUBE. This happen because you must do it every 5 hours aprox of use, The machine protect itself the electronic system and shut down.Maybe the deck belt is worn.
2) LUBE the rollers bearing very i
3) test the drive belt, and test too the bearint of main motor and fix it.
God bless you
Nov 19, 2012 | Life Fitness 95Ti Treadmill 95 Ti
User not detected on belt press enter to continue
you must read you instruction manual, if you do not have download from www.lifefitness. com or www.fitness.manualsonline.com or www.iconservice.com read the section troubleshooting code.
However you must do the following>
1) Test the sensor see the diagram
2) Lube the shaft and gear from elevation motor 3) Test the elevation motor 4( adjust the sensor and clean,and tigh the connector wires.see my personal TIPS for HELP. see the diagram attached.
God bless you
May 24, 2012 | Life Fitness 95Ti Treadmill 95 Ti
When you press Quickstart it says "Please Wait" and it stays like that for about 2 minutes then you can begin workout? Not sure how to fix.
I have seen this a couple of times. The incline motor probably has a gear problem. Remove hood and find the plug for the incline motor, disconnect and then reset treadmill. treadmill should work but will not incline until incline motor is repaired or replaced. Good luck.
Oct 13, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Why does my lifefitness series t screen read immobilized?
I believe the tread has been locked out (safety feature important for clubs) - you can call lifefitness and they will give you the key sequence to unlock it
Sep 21, 2010 | Life Fitness 95Ti Treadmill 95 Ti
I just bought a used life fitness 95ti and it seems to be very noisy when it inclines? is this normal and is there a way to call up how much use the machine has had? Thanks
If its growling then the incline motor is on its last leg. All incline motors have some degree of noise my only suggestion is if their is a Gym in area call them and see if they have Life Fitness treadmill don't worry if it is not the same model. The motor have not change much you should be able to gage noise level on a few of the units. They do not have a total mileage or hour usage if this unit came from a gym a loose figure of 20 to 25,000 miles or 3 to 5,000 hours give or take.
Jun 27, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Life Fitness 95Ti Treadmill 95 Ti Logo
176 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
