Washing machine 12401td front load-on its digital screen tells m
Washing machine 12401td front load-on its digital screen tells mays oe .What does it meqn?
    Genius:
  • 1,416 Answers
what this means is that
The "oe" is an error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
an also means indication that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
what you need to do to fix up this problem is to do what is call general clean up on it by unscrew the key (stroll) and then clean the dry and any form of water in then make sure that all wire are well connected to the position.
Good lock and thanks for using fixya.
Posted on Jun 03, 2010
Washing machine flashing oe
OE = Drain Error • Not fully drained within 10 minutes.
Check and clean the pump filter. The access panel is located on the front, bottom left of the machine. Place a towel under the front of the pump filter access panel opening before opening to catch any water that may flow out.
Check drain hose on the back of the machine for any kinks or blockage.
Dec 18, 2010 | LG WM1814CW Front Load Washer
Machine washes but will not spin and finish the cycle, has OE or DE on screen ??
OE and DE means Open Error and Door Error.
a sensor or wire is loose or broken.
the next question is who is going to do it ? you, a repairman or service center ?
Oct 06, 2010 | LG WM1812C Front Load Washer
Washer has water still in drum and OE on digital readout
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | LG WM-2277HW Front Load Washer
My lg front load washing machine is reading oe
oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
May 20, 2010 | Washing Machines
LG front load washer
That's actually DE (Drain Error). Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
May 06, 2010 | LG WM-2277HW Front Load Washer
Machine has water in it but screen says "OE" what can we do to get the machine working?
Try cleaning the filter, it in the little door on the bottom left side. If its full of water water will drain out. onto the floor. Also it may be over balanced. Switch off, wait a couple of minutes, open the door and rearrange the washing.
Sep 07, 2009 | LG WD14311RD Front Load Washer / Dryer
Washing machine front loader has OE error code
Mine did the same and there was a 20 cent piece in the drain filter which is located at the bottom front left hand side you take off the cover - beware that a lot of water may come out - have towels ready. or your outlet pipe may be blocked. OE is a draining error message
Aug 22, 2009 | LG WM-2277HW Front Load Washer
OE what does this stand for
oe stands for outlet error possible solutions are : drain hose kinked , filter blocked or the pump impellor is blocked.
Jan 02, 2009 | LG WM-2277HW Front Load Washer
Machine stoped
OE is a drain issue.. Check the filter on the front bottom right side of the machine. Make sure its free from debris, also check your drain hose to ensure its not pinched somewhere. If your still having problems, relook at your manual, the error codes and possible solutions should be listed.
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
