Hi, LCD Projector: Hitachi CP-RS55. I pulled out the cable between the laptop and projector BEFORE the laptop had finished powering down. Projector lost power immediately and there was a slight - not loud - sound (possibly the lamp). Unable to power up the projector since. Have changed the plug fuse and removed the lamp, which isn't shattered - just can't tell if it's working. If the lamp has gone, would that prevent the projector powering up or is the problem likely to be more serious. Thanks Dave
  • djcasby Jun 09, 2010
    I've removed and examined the lamp and can't see any damage to it or its cover. I've also tried pushing the reset button on the back of the projector, as per instruction manual (when all else fails). There may be lamp damage - I'm not an expert eye - but am I better to replace the lamp (expensive) or send the projector for repair ... or is there anything else I should check ? Thanks again
    Thanks for getting back so quickly and for the advice
  • 10,865 Answers
Hello. Actually, the reason your bulb blew was most likely that you jarred it a wee bit while it was very, very hot. Replace the bulb and you should be able to power up again. J.
Posted on Jun 09, 2010
    Brigadier General:
  • 3,513 Answers
Yes a burnt out lamp or lamp cover will prevent the projector from powering up. Check to make sure the unit is properly plugged in. Also check to make sure the lamp has not burned out and the lamp cover is properly attached. A burned out lamp or a lamp cover that isn't properly attached will prevent the projector from powering up.
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 03, 2010
  • djcasby Jun 07, 2010
    Thanks - I've removed and examined the lamp and can't see any damage to it or its cover. I've also tried pushing the reset button on the back of the projector, as per instruction manual (when all else fails). There may be lamp damage - I'm not an expert eye - but am I better to replace the lamp (expensive) or send the projector for repair ... or is there anything else I should check ? Thanks again
I have a Hitachi LCD projector model No. CP-RX70. When I connect with my laptop (Compaque) and start both then only starting window XP message appears through projector and laptop works normally but again...
The setup is not correct. Check the requirements of the projector, (size, refresh rates etc.) and set the laptop up accordingly.
You will se the XP Screen because the laptop hasn't loaded any drivers yet and the screen is low resolution.
Hope that helps.
Dec 06, 2010 | Hitachi Performa CP-RS55 Multimedia...
Lcd projector displays the message check air flow
Hi....
Clean the filter
It will show you in the manual
Apr 23, 2010 | Hitachi Performa CP-RS55 Multimedia...
I can't get my laptop to appear on the Hitachi CPRS55 projector
Hello.
Look at your laptop keys and be certain that Fn + F8 is the right combination. Could be Fn + F4, depending on your laptop.
If the key combination is OK, your VGA cable (from the projector to the laptop) could be faulty.
Hope this helps.
Jan 18, 2010 | Hitachi Performa CP-RS55 Multimedia...
Problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Mar 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Hitachi cp-rs55 not working,tic.tic.... noise coming from project
make sure you reset the lamp timer. Manual has the steps. Hitachi Performa CP RS55 3 LCD Projector
if the timer is reset, try cleaning the color wheel. Optoma HD20 Projector Cleaning this video is for an optoma but the color wheel is cleaned the same way in most DLP projectors. Dirty or dusty color wheel sensors cause the projector to shut down and act like its the lamp.
Feb 02, 2018 | Hitachi Performa CP-RS55 Multimedia...
Instruction Manual
Pls try here. You would need Adobe Acrobat Reader to open, view and print this type if file.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
My CP-RS55 Projector Doesn't Work??? No Light?
Hi there
If the unit is brand new , they should replace it under warranty.
This is most probably a faulty Powersupply / Fanboard !
Apr 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Mar 23, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi Performa CP-RS55 Multimedia... Problem
ok " sounds like you have a short, thats why it's blowing fuses
Nov 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
Computers & Internet Logo
David Payne
David Payne
