Baumatic WQP12-9213 - Error Code 004?
Have a Baumatic Electronic Dishwasher Model WQP12-9213 - Has come up with Error Code 004?
    Genius:
  • 1,417 Answers
Hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Posted on Jun 03, 2010
Testimonial: "Thank you for your help."
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
Hello I am getting error code E3 on my Baumatic dishwahser- how may I resolve this? Thank you
its "malfunction of temp sensor or heating element"so it is either the heating element or temp senser.is faulty test and replace the faulty part
Nov 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error Code: 004
shut off power to the unit first or unplug it after 1 min turn back on this may solve the problem
Aug 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error 3 on dishwasher
E3 on BDW45.1 is a failure to reach correct temperature (or the diswasher is unable to dectect the water has reached the correct temperature). You may find the items are not being dried fully.
Feb 21, 2009 | Baumatic 18 in. BDW45.1 Built-in...
Bumatic dishwasher bdw13 showing error code 1
Ok I think I can really help you here.
This is your error code, sounds like it has problems filling, might also be blocked.
‘E1’ LONGER FILL TIME. FAUCET IS NOT OPENED.
Ensure that inlet hose is not
kinked or crushed
Found the online manual for this model, it is a PDF file so you will need 'Adobe Reader' to read it. (click on link)
http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Manuals/BMBDW13.pdf
That should help you
Bri
Feb 07, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BHD5 works then buttons start flashing and it beeps and stops working
Before buying a new control unit, try to unplug the machine for few hours and plug it back in. It might reset the control panel and solve your problem. Good luck!
Aug 01, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Washing Machines Logo
730 people viewed this question
Top Washing Machines Experts
